Joule Thief
0 Members and 41 Guests are viewing this topic.
jeanna
Hi Gary,
I am confused by your drawing then comment.
Do the diodes on your enhanced photo/drawing ALL need to be reversed?
Or is that a corrected drawing? (It seems not... the photo seems to show the diode neg stripe in the opposite way from the way the yellow lines are drawn??
thank you.
I returned the hourglass and I am getting the same 57volts from many more turns around the toroid at the waist.
I am wondering now if I should make the second cone wind around the opposite way.
So, I will watch another video and wind half of it again, this time going the other way.
57v goes to 72 at a peak resonance.
And, there are 3 to 4 resolutions that show a lot of jumping around and ringing that are visible. Also... this is verry interesting: I see that jagged shaped wave that looks just like the EER  we have all seen.
This happens when one full wave encompasses 1.2kHz.
I watched a project camelot interview that talks a lot about this hourglass figure along with many other things.
Joseph Farrell was being interviewed.
It seems this subject is not as unknown as I thought.
And, it seems that it is very ancient as I suspected. Synchronicity abounds.
jeanna
Pirate88179
Jeanna:
Gary went back and edited that the diodes were reversed on his marked up photo.  I'm glad you pointed that out.  Thanks,
resonanceman
Quote from: jeanna on November 13, 2009, 08:20:34 PM
Hi Gary,
thank you.
Jeanna
At  first  I just added a note that   the diodes  were wrong .... later I went back and  changed  them ..and edited  the note .
Mark
Thanks for the information  about  filling the gap
I can't  think of a reason that I  would want to lower  the  frequency .......other than if it  was high enough to be causing  radio interference ......I am pretty sure we are not  getting that high.
innovation_station
IF WE HAVE A PROBLEM WITH THAT I HAVE HIGH GRADE ALUM CASES .. WATER PROOF I WILL SELL REALLY CHEEP THERE MANY SHAPES AND SIZES ...
WOULD WORK GOOD TO SHEILD I BET ...  PROBALLY MAKE A GREAT RECIEVER  TOO !
IST! IF IT IS TRANSMITTING
resonanceman
I finished  my first test JT with  the E cores.
For simplicity I  used a  primary  of 10 turns .
It  had 38 V  with no secondary .
I decided  to make  the  secondarys the same length
I used  12 strands  of  # 26 mag wire .
I twisted  them  into one  strand  with the original primary wires .
I  then  re-wrapped  the  spool .
I ended  up   with   40 V  on both the  primary and  the secondarys
So far  I  have all the primarys  connected  .......like they were all one heavier wire .
It  does seem to have a little power  but nothing  outstanding ..
so far I have not  been able to get it to run  with  the full secondary being used for feedback .
I wondered  about lighting  a filament type  bulb ....... the only one  I had handy  was a 110 V 40 W
It  did not really light up .........but  it made some heat and the  filament glowed a nice  orange color.
gary
