Joule Thief
0 Members and 84 Guests are viewing this topic.
innovation_station
OMG
why didnt i think of this b4 .... lol
crazy
i got THE PERFECT SOLUTION  ;D
i got to find the little cridder ...  darn it!   this coil i made years ago ... it gets hot as hell ... lol and the wire remanis COLD...   DUH ... I LOVE IT WHEN I HAVE STUPID MOMENTS ....
i will find you a picture of this coil ... lol  ;D ;D ;D ;D
me!
it is made from a peice of iron pipe un cut ... the engery can not release .. so the metal gets soooooo hot sooooo fast!  8)
you know some times i amaze myself lol
there is the element .. for the hot water unit ...  drop it in the tank ..  the engery is not wasted ... it is accelerated to the point of heat !
i cant find the picture .. it will be easyer to unpack it and snap a new one ... i cant even remember where it is posted lotr or gk's heterodyning thred ...
this was a long time ago  but i know it will work great and cost pennies to make and it will use verry little power as i recall it was pulsed really slow ....  ;)   like 1.6hz or 2 max i was useing the lite puter it would max at 2.2hz there bouts  and i used a 12vdc 1 amp supply in a few seconds it was hot but yet the wires were cold ...   this is b4 i put the wires through  the steel core  so the compounded magnet engery could release from the steel 90 deg to the copper collector output
now how about useing the wire J is talking about and insulating it from a steel core it gets hot as it is suspoto but it allso will induce a magnetic feild in the uncut ring core ...  adding even more heat !
i have used steel wires b4 as pulse and gen coils ... on a toroide .. with out any diffrance vs copper .. not sure why that is ...
resonanceman
Quote from: innovation_station on November 20, 2009, 09:34:58 PM
OMG
crazy
me!
Great  idea IST
Induction  furnaces for melting metal  work  along  that same principle
They are basically one  big  coil .......the  metal they are melting acts like a  single piece  winding
gary
gadgetmall
Morning . Experiment 2 part 2 is failing to get to 1.4 volts probably cause the kitten jumped on the experiment and disconnected the charge battery which lost several hours worth of primary Bcap Voltage . Run this morn is .808  and Charge is 1.353 . Its still running but Charge is slowing down . . On the other hand  another Jt i made exactly like the other two is still going strong on the EverReady rechargeable 2500mah battery . its volts is still 1.277 . these are good batterys . its powering 1 watt of leds also . I could charge many 650farad caps up with that battery and standard Jt . it just take time . Well i dont see Experiment 2 part 2 the swap on the caps reching full charge so i decided to swap them a third time and see if i can bring the .808 volt cap up to at least 1.3 volts . Thus experiment 2 part 3 .
Update the .808 is now .904 and the run cap is 1.297  at 10:20 am . It appears the Joule thief needs at least 1 volt to charge .
innovation_station
then it is a good thing the 2n2222a's dont drain the run caps fully ...  ;D ;)
so you only need to top up half the cap ... from the out put useing a 12vdc step down adaptor cord ...
gadget ... you still run ip's ?   as this dink wont buzz off ... he has almost caused me to release teleportation ... this darn world is barly ready for the darn jt...
yikes ..
i think he needs a time out ...  ;)
w
gadgetmall
Experiment 2 part3  / third swap of ultracapacitors . the kittenfumbled run Bcap is 1.214 and the charge Bcap is .999 now it 1.000.
here is the latest Diagram of the joule thief aa battery heater showing you the hook up for the multimeter to see the current draw of your circiut .If you use exact parts this circuit is adjustable from 8 ma to 22 ma input. The 1 watt worth of leds do not draw any current that i see . they were for on indicator for the oscillating 2n2222a . As a sid effect they produce a good amount of light and get brighter as the Charge Bcap gets higher in Voltage .
