Joule Thief
0 Members and 64 Guests are viewing this topic.
PaulLowrance
Quote from: gadgetmall on November 21, 2009, 11:43:19 AM
Hi Paul .Its very possible he is seeing gain . I have demonstrated over the unity of a primary source in the Jule thief thread . from an aa battery 2500mah i have charger an ultracapacitor to full capacity with only a few microvolts of loss from the battery 1.4 volt battery . I have stored 3500 AMPS that burn wire and produce HEAT while producing light at the same time . this Amperage is not cold electricity . The worlds first aa battery nichrome heater / light schematic is on page  997 thru 1002 and there is an ongoing experiment . this is easily replicated and you can build one it about 5 minutes
Gadget,
That's great. So your 2500mAH battery fully charged the "ultracapacitor" without much loss from the 2500mAH battery? Is this the circuit you used for that experiment,
http://www.overunity.com/index.php?action=dlattach;topic=6123.0;attach=39124;image
Paul
gadgetmall
Quote from: PaulLowrance on November 21, 2009, 12:36:06 PM
Gadget,
Paul
Hi Paul . use the above circuit posted before your post . This is correct i only lost 5 1000's of volt from the start of Experiment 1 for IST . This is OU in a simple demonstration / So far i have tested "supercaps and batteries and they don't exhibit the effect like this Bcab Does . I have been asking for replications done to triple verify my finding s. you suppose i could enter in the Ou contest Now ? there cheap enough to build . well under 100 dollars .
PaulLowrance
Hi,
Can someone recommend the best OU device that will charge a battery? I like the slayer007 claim, but so far can't get enough details from him to build it. Slayer007 took two dead 9V batteries and charged a 12V 80AH that was ~ 16% charged and charged it to ~ 62%, which means the device added 132000 joules of energy. Even if both of his 9V 250mAH batteries were fully charged, which they were not, that's only 2 * 0.250 AH * 3600 = 1800 joules.
That's amazing!! That's what I'm looking for to replicate. Can someone recommend something,  preferably from someone that is upfront and non-evasive who actually wants their claim replicated and verified? Gadgets claim seems great as well. Maybe that's the best one to replicate.
Thanks,
Paul
Pirate88179
Paul:
I would recommend either of them as they are both excellent experimenters and have done some great work.  Gadget's is the most recent as he has just had a break through in the past day or so, and it does not sound complicated to replicate.  His complete drawing has been supplied already a page back I believe.
Everyone needs to get some of these large ultracaps.  Mine is the 650 Farad size and I have been able to do amazing things with it.  Gadget says he will soon be getting bigger ones around 1,400 Farad!  Man, you could arc weld with that much power!
PaulLowrance
Quote from: gadgetmall on November 21, 2009, 12:45:47 PM
Hi Paul . use the above circuit posted before your post . This is correct i only lost 5 1000's of volt from the start of Experiment 1 for IST . This is OU in a simple demonstration / So far i have tested "supercaps and batteries and they don't exhibit the effect like this Bcab Does . I have been asking for replications done to triple verify my finding s. you suppose i could enter in the Ou contest Now ? there cheap enough to build . well under 100 dollars.
Hi Gadget,
Have you tried charging a car battery? Slayer007 claims it worked on his 80AH battery. It would be better to use a car battery because most people have one, in their car, including myself. I don't have one of those ultracaps, and can't spend $100 on one anytime soon.
Paul
