Why does mass slow time?
Started by gravityblock, November 25, 2008, 05:31:30 AM
onthecuttingedge2005
Hi Gb.
I will discuss this when I am more humane, I have studied 'all' the books and I can tell you it is the future Earth and not aliens. you don't have much faith in mankind achieving time travel do you?
Mankind designing your future, it is atrocious isn't it.
It will happen, infact it is already happening. have more faith in your own species.
Jerry
gravityblock
Quote from: onthecuttingedge2005 on June 19, 2009, 03:11:43 AM
Hi Gb.
Jerry
I think it is possible for mankind to achieve time travel.  I'll have more faith in my species once they have been enlightened.  If this has occurred in the future of mankind, then this is no surprise to me.  It has already been written.  After saying this, I will always put my faith and belief in my God before my species any day.
It is also written, that there will be miraculous signs and wonders in the heavens.  Many will worship and give power to the beast who is performing the miraculous signs and wonders, and will deceive even the elect of God.
I am fully aware of what lies ahead and have put on the whole Armour of God.
I can not make a more constructive comment at this time until there is a further discussion.
Maybe you getting smashed again like the other night.  Have to wait and see where this is going.
PYRODIN123321
The problem with the churches, is the people are misinterpreting the scriptures to fit their own ideas, while the text is accurate.  Also the churches have rejected certain manuscripts that are key to understanding the mystery, such as the Books of Enoch.  There is a lot of symbolic language used in the ancient manuscripts, which is read out of context.
I agree with that
GB:
when you say gravity is only working one way, I think this is not right...
Before the universe was as it is now a massive input of energy somewhere must have occurred
the force of gravity is just restoring things back to their original state......at some point the earth and the sun were not separated and everything was all together then (if you follow the big bang theory) things were spread out and gravity just pulls them back in....
so any energy you could extract from gravity would only be stored potential energy from separation
just like two magnets, it takes energy to pull them apart and releases when they are drawn back together.....
Peace.
gravityblock
Quote from: PYRODIN123321 on June 19, 2009, 12:25:20 PM
GB:
I think you misinterpreted what I meant by gravity working only one way.  It is working in attraction mode, and doesn't have a side to it that repels like the magnets.  If gravity could be manipulated to work in repulsive mode, anti-gravity, then you don't need to worry about energy to pull them apart.  All you need to do is ride the gravity/anti-gravity waves.  I'm trying to keep things simple here, without getting into the complexity of things.
Gravity is not the only player in the game.  Galaxies on average are actually moving away from each other and not coming together and according to current observations the universe is still expanding.  Yes, some galaxies are on a collision course and attracting towards each other.  This is due to them being under the influences of each other's mass.  As well as being pulled on by gravity, galaxies also ride along with the overall expansion of the Universe.
Maybe the universe is expanding and contracting and could be said to be breathing. We just haven't had enough time to observe it inhaling yet.
I don't think it takes energy to do work.  I think all it takes is to have an unequal or non uniform force acting on an entity that does not cancel each others force in order for work to be done.  Weather the forces are uniform with no work being done, or the forces are non uniform with work being done, there is no loss or gain either way.  This means it doesn't require more energy or more force to do work, than it requires not to do any work.  Actually it would require less energy or force in order for there to be work done, than not to do any work at all.
Back to the water wheel real quick.  Have two equal streams of water flowing past the wheel in opposite directions where the two streams are divided as they flow past the wheel.  No work will be done and the wheel won't spin.  Remove one of the streams or forces and work will be done and cause the wheel to spin.  It is doing work with less forces involved than not doing any work at all.  Sometimes more is not always better.
Regarding the future.  I believe that there is a future that is moving towards us.  Our present is there future and their present is our future.  They are not moving backwards in time, just as we are not moving backwards in time.  They are only moving in time from an opposite direction than us.  Let's say they are moving from North to South, and we are moving from South to North.  There is also a time that is moving from East to West, and a time that is moving from West to East.
Time is moving in an infinite many number of directions.  There are only 4 dimensions in our universe.  Length, width, height, and time.  Time is the X factor that can make up an infinite number of other universes each having it's own 4 dimensions.
Time travel only requires you to change the polarity of time that you are currently in.  Once you successfully changed your direction of time, then you would be coming from the future into the past.
Time also has a frequency.  If you can control the frequency of Time, then you can control how fast or slow you are moving in time.  This allows you to either move in the direction of your future or the direction of the past at your desired speed according to the polarity of Time you have chosen.
Faster than light travel is possible by changing the frequency of Time that you are currently in.
Just like the radio, you have different frequencies.  You can't listen to what is happening on another frequency unless you tune into that frequency.  Time has a frequency that can be altered to a different Time.
I assume the amplitude of Time would allow you to move Perpendicular in Time. Moving from South to North, then from North to the east and so on.
Yes, this is all speculation.  It is a very real possibility though.  As I heard one person say, nature is bipolar as hell.  Female/male, north/south, east/west, negative/positve, clockwise/counter-clockwise, up/down, heads/tails, good/evil, gravity/anti-gravity, matter/anti-matter, right/left, forward time/reverse time, wisdom/folly, rich/poor, future/past, slow/fast, attraction/repulsion, contraction/expansion, etc.
Below is a map of the local universe.  This map has recorded the positions of more than 110,000 galaxies over more than 80% of the Southern sky, out to about two thousand million light-years from Earth, (a redshift of 0.15).
This map is by no means complete.
PYRODIN123321
I agree things are very dual, so maybe there is some hidden knowledge there....
would be cool to be able to manipulate time, but how? If it was like electromagnetics -a material or process that could transfer energy into to manipulate time....kind of like the way we transfer motion to electricity, we need a way to transfer electricity to ??? I dunno, the closest I have seen to something like that is T.T. Browns stuff....
Peace.
