locating Steve Mark´s TPU demonstration house
Started by EMdevices, November 22, 2008, 09:00:43 PM
wattsup
@EM
Good going man. This is very pertinent. Too bad the video is too big for uTube.
Can you let us know the model of your VLF meter as I would like to try and find the schematic diagram of that meter to see if there is anything such as components or general function that could be used in a TPU????
According to my current tests of a FTPU build and the relationship between the outer ring and outer coils, THERE IS NOTHING happening in the transitional coupling sense at 5000hz range. I have seen good coupling action at the 2mhz and above levels if it is driven under a coupling energy transfer scheme.
If anyone can calculate the resistor,capacitor and transistor values for pulsing a coil at 2mhz or above, consider the outer coils have an ohmage of 0.1 to 0.2 if that helps any. Even with the number of wire turns in outer coils of the OPTU, STPU and 6TPU should be about the same ohmage. It would basically be like pulsing against a short circuit. Figure the center toroid coils have an ohmage of about 2.5 to 3.5. But there is nothing openly seen to be able to have an ohmage in the 30 to 150 range. Nothing. I know I asked this before but apparently I needed to know the coil ohmage. The basic diagram is located here but I need some values for the components.
http://www.overunity.com/index.php?topic=5486.msg156190#msg156190
Now if there is a way to consider the same builds but in the VLF receiving scheme using some simple components, this would be something to consider very seriously at this stage in order to work at both angles.
I built a few FTPU and 6TPU style coil cages and will take then near the HV lines this week and put my multi-meter on them to see if anything happens.
forest
 :P
Why don't you take a garden hose, fill with water and investigate how the force of two fingers could be used to move water inside hose by squeezing it along the length ?
Garden-Hose-TPU   :o
BEP
@[marco]
Nice matching job!
@EM
I assume you have an audio output on that device of yours? You then fed it into your 'puter?
The point that really interests me is a 5.8.
BTW: Are there any power lines running to the house? Maybe they picked up a real bargain when they bought the house?
hartiberlin
Quote from: EMdevices on March 17, 2009, 12:43:27 AM
I'll upload a movie for you guys shortly.....
http://www.youtube.com/watch?v=E1pF9PL9Mbw
EM
Youtube deleted your video.
Please upload it to video.google.com
cause they allow much longer videos.
Many thanks.
Regards, Stefan.
EMdevices
Ok,  I deleted the longer video which youtube would not allow, and I edited it down to just about 9 minutes, so they should accepted it now.
Here's the link:
http://www.youtube.com/watch?v=9LJmAW7hYak
Enjoy !!
EM
P.S.  wattsup, the meter is my own design, it's just a pickup coil with about 100+ turns on a ferrite and amplified about 100 times or so, works great except when excessive fields are present, then distortion sets in.
