Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
sparks
     Unipolar magfield coupling.  Some force always desaturates a choke coil.
Like in cook coils or hubbard coils or flyback transformers or automobile ignition coil transformers or Leedskalins keeper sliding.  We may pileup the blocks and take a microsecond.  But what force knocks the wall over in a nanosecond.   I like sawtooth wave input.  Tight couple to the ramp and loose couple to the slam.  Work going in and more free work when you shut the voltage OFF.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
So which version of the MEyer transformer are we talking about - 2 windings or 5 windings?
If Meyer's had the burst wave - then he may be correct about what he called "universal energy".
I see in other diagrams that he just shows a trigger transformer with a common ground - probably the little 3-prong type.
As for all his talk of "resonance" and calling the water cell a capacitor - I recommend that everyone take this with a pinch of salt.  He indicates that "resonance" was the condition that rpoduced the most output.  He talks about the water capacitor resonating but says you can increase the surface area to increase the output or increase the pulse rate.  Also, notice that he applies burst of pulses and then a pause, and that the repetition rate is low  kHz, but the pulses are very short.
I think I know what he is really doing and it is much simpler than anything I have heard to date.  Won't have time to try anything until next weekend.
        -Frank Edwards
Grumpy
Quote from: TheBuzz on December 15, 2008, 10:43:15 AM
I never said anything about matter being made of Aether.
Correct.  I did not mean to imply that that you said this.
Let's talk about unipolar fields since that is important and everybody seems to gloss right over that.
Tell me everything you know about that.
Well, I jsut recently found out that they can exist and there apparently is little info available on unipolar fields, electric or magnetic, so I know very little.
Some theories allow electric and magnetic unipolar fields, but magnetic unipolar fields are not "required" - of course this leaves a big "what if" hanging around that is never addressed even in theories.  Electric monopolar current is just standard electric current.
Following is what I think is correct - largely assumptive:
1. Magnetic monopolar currents exist in a closed medium of high magnetic permability.  An open core will not produce these as the space outiside the core is dielectric and can only conduct dipolar currents - so closed core.  This may be incorrect as monopolar currents may exist within the core before the path is closed.
2. Magnetic monopolar current is momentary or unstable (even "dangerous") - hence they are induced by an impulse at the intial rise fo the pulse and to a much lesser degree at the fall - this could be backwards as everything between electric and magnetic seems to be backwards.
3. Repeated pulsing - producing MMC - may cavitate at a certain rate of pulsing and this is very interesting.  It may build to one hell of a level of energy at the correct rate.
4.  MMC's may attract conductors and magnetic objects, and this may actually be the cause of something associated with the MMC, but I am laying out enough for you to get my drift, so I'll leave that out of this so we can just focus on cavitation.
There are maybe a handful of people on this rock that even know what I just said - for them - this Bud's for you!  For everyone else - stay out of it - I'll probably be phone tapped shortly.
EDIT:
The more I read about Meyer, the more he sounds like many others researchers - cryptic and paranoid.  I don't place too much faith in the core and transformer since he was able to get the goods through other means.  Impulses = yes, fancy transformer = optional.
scrounging for some stainless now.
        -Frank Edwards
sparks
The concept of a mmc is not that hard to grasp.  Take a long solenoid coil and form it into a torroid.  The B poles disappear.  The torriodal core can then be variably saturated inducing a kinda peristalsic magnetic current.  Isn't that how they build particle accelerators?
Think Legacy
Spread the Love
sparks
  You take a mwtube and get rid of the 60hz voltage multiplier circuit and use an efficient kicker things get exciting.  I did a water to plazma conversion with a couple of paper clips and a bottle cap of water.  The hydrogen production is the least of your worries.  The blue color of the plazma tells you that electrons have exceeded the speed of light through the water vapor.  This only supposed to happen in heavy water surrounding a fission core.  You can get the same effect with 30kvpulsed scource some iron wire and a hunk of plastic.  Earth just loves to give up it's charge to a selfconfined plasma field.   Arc of the covenant kinda shit.
Think Legacy
Spread the Love
