Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
PaulLowrance
OK, anyone, here's a search for Methernitha at peswiki.com
http://peswiki.com/index.php/Special:Search?search=Methernitha&go=Go
I see references to Methernitha Testatika. Is that the device Methernitha?
Thanks,
PL
Pirate88179
No Buzz, actually you are the one polluting this topic with useless posts.  You keep posting the same thing over and over again and yet, you do not answer any questions.  And, better yet, you have Chet to chime in and repost all of your useless posts.  When you posit such a broad theory of "everything free energy" you should at least expect a few questions.  Calling folks names (trolls comes to mind) and accusing them of what it is you are doing, is very unprofessional and unproductive.  I asked you many times to start your own topic for this type of posting that you seem like you have to do.  You have, and no one posts there.  Big surprise to me.  Maybe folks don't like your abuse?
Anyway, I have had it with your abuse of the good members of this forum and I am requesting that Stefan lock MY topic.
Thank you, nice job.  Another topic stopped.
Grumpy
Paul is somehow a "debunker", I'm not sure of the exact connection, it may be subliminal.  You can tell by what he chooses to respond to and what he ignores. Basically, if he can counter he responds to it, of not, he ignores it.  Anyone truly looking for alternative energy would have more interest in some of the things posted on this thread so far - absolute gems - but trolls always ignore gems unless they can readily respond and refute them.
Not sure if Chet is involved yet, definite possibility.  Perhaps his art is coaxing and prodding. I_S can squeeze blood out of a turnip - pretty slick at it too.
Pirate - go ahead and lock the topic, but unless you delete every post, the seed is planted.
Methernitha was reviewed by Dr. Stephan Marinov, a physicist, who could not explain the device's means of operation.
        -Frank Edwards
Grumpy
Quote from: sparks on December 30, 2008, 06:39:54 PM
       The problem with Tesla's work was there was too many waterfalls around.  His idea was wireless power transmission using hf hv.  So he wasn't in to any overunity devices.  So when he describes a system using resonance to boot up or store power in a resonating system he thinks it is marvelous because now you can take the horsepower of the generator and dump it into a resonating system for maybe a few milliseconds and let her go through a transformer that pumps up a capacitor to alot of volts.  Now once this capacitor is maxed out you dump it into an inductor where it results in alot of ringing and magnetic pulses inside the motor  as the oscillations ring down.  Where is the gain in all this system.  Why not just run the motor off of the input voltage.   Cause capacitors store up time.  You can put 10watts in for 10 milliseconds and change it all into voltage inside the cap.  Or you could just power a dc motor and piss away the 10watts for 10milliseconds.  Now if you got this capacitor at a high voltage potential and you dump the voltage into a system that resonates now the motor gets magnetic energy which collapses and charges the capacitor back up which discharges into the motor again etc.  It osciallates the system or vibrates the system.  More in then out.  For sure if your oscillations are 10watts for 1000 milliseconds.    A gain in voltage at the expense of time is very much retrievable.  A coil of high selfinductance takes it's sweet time manifesting the higher potential at it's terminals.
Tesla did not use HF.   HE couldn't have.  You are right about the coil taking it's sweet time.
        -Frank Edwards
Grumpy
Quote from: PaulLowrance on December 30, 2008, 02:39:22 PM
You obviously didn't read the wikipedia page. You never read anything I link to.  :D  Read it again.
Are you claiming my diode array does not produce DC power across a load???
PL
I read it.  I ignore most of your link as I suspect that they are just propaganda.
I'm claiming your diode array does not produce "useful" power across a load - which I believe you already admitted.
        -Frank Edwards
