RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 59 Guests are viewing this topic.
Groundloop
@TinselKoala,
You have built a very nice Tesla coil. :-)
I agree to your comments but must point out that Luc did load the output coil with resistors ALL THE TIME.
So he is not just measuring a one "pulse energy scheme". If it is correct as you say that we can load with
as many coils we want from one resonating system (and it certainly looks that we could) then perhaps
over unity is within reach.
Groundloop.
Sparks brings up a good point--in the Tesla system the capacity is actually the space surrounding the coil, and it might be possible for energy to enter the system from this avenue.
Groundloop--I understand that, but I also see the RCL circuit on gotoluc's resonant tuned secondaries as having a time constant, and until I can replicate that part exactly, I won't know for sure that the power on those elements is constant over time. In my NON_TUNED partial replication, the addition of any small resistance across my receiving cap prevents it from charging at all, as I have discovered this morning.
Groundloop
@TinselKoala,
OK, I understand. If you load the output coil with a too low resistive load then you off tune the LC part so much that
you end outside the input frequency. I think these circuits must be treated as radio frequency circuits. That is way I
added a variable capacitor at each secondary coil. This capacitor will enable the researcher to individually tune
each LC part of the circuit. The coils must also be designed with a high impedance primary and a low impedance
secondary to best match the load. It will be like a Tesla coil in reverse. :-)
[EDIT] Attached is a image of my high voltage step down air core transformer. (Tesla coil in reverse). The big coil
          is approx. 2000 turns and the output coil is 2 x 2 turns with center tapping.
Groundloop.
sparks
     The top load is just one plate of the capacitor.  The other plate is Earth.
This makes a tank circuit but the capacitance is inputting voltage differential between the top load and Earth every cycle.  You really don't want this thing going radiant so if it is setup for low frequency the gain should not be blown away into transverse waves.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
gotoluc
