RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
Kator01
Hello Observer,
QuoteFrom what I can tell, I am still the only person who understands this as a viable phenomenon for an overunity device.
Are you ? It seems you are a lonley person ?
You could  change this.
Why not share your knowledge about the ou-possibilities based on permeability ?
At least I also am very much concerned about permeabilty especially the perm of pure iron.
Kator01
gotoluc
Quote from: armagdn03 on December 05, 2008, 06:13:30 PM
Glutoc
Bomb Sh*t Dude. You are one of the first to have started to take these concepts to the next level. I have been unable to post, make comments, or further my demonstrations at this time due to other time commitments, however I am very happy to see that you have taken something valuable from it.
One thing that you can take into consideration with the original circuit. The primary and cap will have a resonant frequency, and the secondary with its parasitic capacitance will as well. It is unlikely that you are hitting the resonant freq of the secondary. This is why I showed the youtube video of the different resonant modes of a secondary. It is likely that your primary tank circuit is the one you are hitting resonance with, if you get this to match your secondary resonance, you will be pleasantly surprised. Also, it should be noted that any change on the loading of the Avramenkos plug will affect the resonant point of the secondary, and a bit of re tuning may need to happen.
I could go on an on with what to improve where, but lets keep it simple for now, great job, and thanks.
Hi armagdn03,
thanks for taking the time to look at this topic and to post some pointers ;)
Test 1 video was not all that good of a circuit as I had though at the time. If you look at the circuit you will see that the primary is directly connected in series with the secondary, so it was just like one coil. However test 2 (just posted above) gives a better result and is just a single coil with its cap in series.
The Avramenkos plug is a really interesting animal and seems great for extracting energy from a resonating circuit without having a degrading effect on the circuit.
I will try more combinations and will post new videos one I get improvements.
Thanks for your great help and sharing.
Luc
The Observer
Kator,
Thanks for you response.
Last Summer is when I explored the science of Magnetic Permeability in the following thread.
                http://www.overunity.com/index.php?topic=4831.0
If you take the time to read this post, you will find some answers as well as realize that I have tried to share this.
Not many if any grasped my initial concern that ferromagnetic materials amplify the magnetic field of a coil by 1000's of times !
I don't see anyone talking about this !!
        yet close observation of the formula that calculates the magnetic field of a coil reveals an interesting phenom.
As I did theoretical research on magnetics the record will show that
                                              I came to the conclusion that a resonating transformer would be worthy of experimenting with.
Hense the aforementioned Electronics Set and my Resonance Transformer Experiments.
To be slightly more specific.
      I made a simple oscillating circuit with a transistor, a capacitor and an inductor (an audio transformer hooked up to a speaker)
      I tried every frequency by changing the resistance.
      At a specific frequency near the top end of human hearing... the sound from the speaker got very loud.
     I found that I could light up 3 volt LED with a 1.5 Volt battery only at that frequency.
     I found that the transformer itself vibrates and makes a sound at that frequency.
     I produced a continuous loud audible sound for 7 days with a 1.5 volt non-alkaline battery.
I definitely need to do more... and will have time during the winter months to expand on this.
Otherwise... I suggest this,
                                                EXPERIMENT WITH TRANSFORMERS AND THEIR RESONANT FREQUENCIES.
Yours Truly,
                     The Observer
gotoluc
Quote from: kewlhead on December 05, 2008, 08:14:43 PM
Hi Luc, thank you for sharing....  a question about the ground, does removing the ground wire apply an arbitrary ground or is it the other way .... attactching the wire is an arbitray ground?
Hi kewlhead,
I'm not sure if I really understand your question ???... the coil is resonating with square wave AC but the Capacitor is charged by DC via the dual diodes off one side of the coil. Adding the Earth ground to either the positive or negative side of the diode plug increases the charge voltage for a reason I do not yet understand. Is it extracting that energy from the Earth?... I think it is but I can't prove it.
Hope this helps.
Luc
najman100
Hello LUC
i just watched your vid2 and i wonder if you apply dc square will you get the same effect ?
Najman
