RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
najman100
Quote from: Groundloop on December 23, 2008, 12:20:31 AM
@najman100,
OK, I will download the version 5.3.0 and install it on my laptop and test the files.
Groundloop.
do you have skype
ramset
Groundloop
I am completely at a loss for words [I have been lusting after this]
I must admit you impress me no end with your skills and benevolence [the time you take to help others]
I have been watching Luc for some time [the THANE wars] and he is of like spirit
you have the dream team here TINSEL Koala and many more
I will endeavor to put your gift to good use [I have some cool ideas] and will share all
God bless
Chet
PS I would like Luc's Paypal
Thanks Grandma
najman100
Quote from: najman100 on December 23, 2008, 12:22:42 AM
do you have skype
i managed to open it do not know how LOL  but now i want to print the lower and upper  traces  separate can we do that ?
gotoluc
Thanks Groundloop for all the Christmas spirit ;)
You're beginning to be a regular Santa Claus ;D
I'm glad you're building some coils. You know, I think we could use some lamp or 18 gauge speaker wire, as I think there could be a benefit to having an air space between the wires. I know for sure the pickup coil works better with about 5mm space away from the mag wire. I was going to test the speaker wire but yesterday I fried something on my board :( ... I thought it was one of the transistors but after taking them all off I found it is both IR2103's  are sending switch pulses to only the far right transistors ???... I had a hard time believing that both would go? that's why I took all the transistors off but now it's sure it's the IR2103's :P
Everything was going well, I was testing with 3 coils but with no loads on the capacitors and at one point when I was adjusting the proximity of each coil the voltage on each climbed pass 22vdc (no load) and that is when it stopped working :(
I was having so much fun ;D
Anyway, going to have to build a new one since I soldered the  IR2103's on that project board :P ... this time I'm picking up some sockets for everything, even the transistors.
Luc
Groundloop
@najman100,
I downloaded the newest Eagle CAD version 5.3.0 and installed it on my Laptop running Win XP.
I had NO problems opening the files. I did a test and generated GERBER design files in inch
and it worked 100%. To make it clear, open the *.BRD or the *, SCH file.
You can select export image in the file menu. But, there is more. First you must go to the View folder
and select the correct layer you want to print out! Just deselect ALL layers first. Then select TOP layer
and export that. After that you select the Bottom layer and export that. Click the Monochrome box
before saving the image. You can save as large image as you want by increasing the resolution DPI.
Hope this helps.
Groundloop.
