RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
Groundloop
@ramset,
Thanks for the positive comments. :-)
Groundloop.
gotoluc
Quote from: ramset on December 23, 2008, 12:35:04 AM
Groundloop
I am completely at a loss for words [I have been lusting after this]
I must admit you impress me no end with your skills and benevolence [the time you take to help others]
I have been watching Luc for some time [the THANE wars] and he is of like spirit
you have the dream team here TINSEL Koala and many more
I will endeavor to put your gift to good use [I have some cool ideas] and will share all
God bless
Chet
PS I would like Luc's Paypal
Hi Chet,
thanks for your positive comments ;)
I just bought some supplies on ebay and for the last item I'm short by $5. to purchase a set of 6  12vdc 4.5AH sealed lead batteries for the self charge setup test. I see you were asking for my PayPal but I'm not to sure why, however if you can help out by sending me $5. that would complete everything I needed.
My PayPal is my email address: gotoluc@yahoo.com
Thanks for sharing
Luc
najman100
Quote from: Groundloop on December 23, 2008, 12:47:37 AM
@najman100,
I downloaded the newest Eagle CAD version 5.3.0 and installed it on my Laptop running Win XP.
I had NO problems opening the files. I did a test and generated GERBER design files in inch
and it worked 100%. To make it clear, open the *.BRD or the *, SCH file.
You can select export image in the file menu. But, there is more. First you must go to the View folder
and select the correct layer you want to print out! Just deselect ALL layers first. Then select TOP layer
and export that. After that you select the Bottom layer and export that. Click the Monochrome box
before saving the image. You can save as large image as you want by increasing the resolution DPI.
Hope this helps.
Groundloop.
finally i managed to make the changes i guess i will sleep tonight less stupid LOL ;D ;D ;D ;D
thanks Groudloop i was having a hard time with that software  i will work on that tomorrow and will keep everyone posted .
Najman
Groundloop
@Gotoluc,
>>You're beginning to be a regular Santa Claus
I was born in north Norway very close to the north Pole. So I personally know Mr. Santa. LOL
I will be looking into the wire issue. I agree that using plastic insulated wire will give some distance
between the wires. I will search my storage for such wire. It is no problem to put the secondary coil
5 mm away from the primary. You are thinking that the secondary coil will have a diameter that is 5 mm
more and sit outside the primary coil?
You are driving the IR2103's pretty hard with only 10 ohm resistors. Change to 50 ohm resistors
and add the decoupling capacitors as shown in the newest drawing. Using sockets is a good idea.
[EDIT] Attached is a proposed way to make the coils. You will have to fill in the blanks.
Groundloop.
ramset
LUC
Because YOU ARE THE RIGHT STUFF
One in a zillion [billion at least]
I'm working out of state
my wife is sending Now
God bless and merry christmas
Chet
Thanks Grandma
