RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 52 Guests are viewing this topic.
armagdn03
Quote from: Grumpy on January 04, 2009, 10:38:46 PM
Sparks pays attention when briefed.  ;D  Kudos and all due respect to you sir!
LMD wave is in the dielectric of the coax, condcutor is a guide.
Answers to questions - may all "trolls" break out a fresh pen for the log book.
1. Why did Tesla use the pancake coil arrangement?
Tesla found that a compression field was produced inside a circular conductor, rarefaction field (decompression is produced outside a circular coil).  This compression field is transformed by the secondary, resulting in a very high potential.  Depending on the variables the highest potential may NOT be at LC resonance, hence he tuned for effect.  The compression only occurs during the rise of the pulse, with decompression occurring at the fall of the pulse.  Like I have said over and over - compress - compress - compress - no decompression or you lose it.  Back many years ago this was loosely referred to as "field pumping" by some basement experimenters - 1000:1 gain.  As far as I know they are all gone as I can locate none of them.
What am I talkin' about?  CAVITATION OF THE MEDIUM ITSELF!
2. Why is the primary outside the secondary?  Why MUST it be this way?
The compression field will always be inside a circular conductor, to be outiside would force it to expand which is not the way it works.
3. What is the nature of the field produced in the space outside the "extra coil" and top terminal?
The "current" produced in this space is a mass-free polarization current.  No ions. No electrons.  It literally runs with gain and can achieve astronomical levels - literally.
4. Why is it a dielectric effect and not a reactive power one?
Different direction.   Reactive power is a state of storage not a current.
5. Regarding Tesla's short strap, what was occurring along its length?
If we refer to the same thing, then the short strap is a primary and not a coil of high self-induction which would have the loads connected to it.
Cold electricity is like a pressurized energy state - it seeks to balance - to relieve the pressure - like everything else.
Something else of note, when Tesla referred to "currents of conduction" - in what medium was he referring to?  Not a conductor, but a dielectric medium!
I also dont want to get into a pissing contest, so I will not reply to any of the statements you have made, (im not saying you are wrong!) But I do want to point out that you have pointed out more effects without pointing out how they should be used. If it is energy we are after, how do these observations lead us in that direction?
I wish I could turn my brain off sometimes, then I could get some sleep.
gotoluc
I really appreciate everyone's comments ;D... this is good but I would like to also remind you that myself and I'm sure many other who maybe in the background reading this topic would like to see some kind of working or even semi working device demonstrating what is being shared here.
How about we start this New Year with this new frame of mind!... We build and demonstrate what we share ;)... and if we don't have the ability to build, then we submit a detailed proposal of what is needed to see if someone is ready or capable to take on the task.
If we really want change, then we will have to get involve in some kind of physical testing of all this great information being shared here.
Lets work at re-inventing our World :)
Thanks for sharing and your understanding
Luc
Grumpy
Quote from: armagdn03 on January 04, 2009, 11:20:36 PM
See the answer to number 3.
It all started when Tesla noted the forces of compression and rarefaction when the switch wa thrown - compression it's not really "stronger" - just focused - whereas rarefaction is going out in all directions - which is why it is cold - just like releasing air from a tank.  Notice that cold electricity moves along the conductor to dipoles such as capacitors (top terminal of a magnifier and plate in the ground), batteries (Bedini is actually correct), and planet earth (from the sun).
Remember Dollard's video with the two Tesla Transformers when he lit some bulbs and the copper rod was attracted to them?  The cold current, as it is called, resides between the transformers.  So, they are transformers in the sense that they increase voltage withing their windings, and they are coverters.  Look at Tesla's famous images of the various means to convert by discharge (keep in mind that all use a coil of high self-induction which is not depicted very well by a short line).
Remember the tale of Tesla's discovery of magnification?  When he placed a coil within his thick opper strapped and applied impulses to it?  That was not LC resonance, not with some arbitrary coil place within a copper loop.
Does everyone remember the Sun/earth/TPU image posted by Sauron a long time ago?  and his references to tuning forks?
Sorry for mucking up the "resonance" thread.  I'll let you all get back to that.
        -Frank Edwards
clone477
Gotoluc,  Thanks for leading me to the osilliscope that you are using I will be buying one.  With your redo of Armadn03 resonances with a coil, and two light bulbs, one within the LC and the other before the LC to show current draw.
I understood this before UNTIL you showed that different cap values actually increased or decreased the amount of current draw from the FG.  I just thought that when you put a different value cap in, and readjust the FG to the new resonant frequency of the coil, that was it.  Can someone explain why the dirrent value caps, even though they were all tuned to resonance, gave different current draw from the FG.
Second, Ive been on the side lines following and listening and wanted to congratulate all on the progress of this thread.
I got really confused when this circuit came into play that everyone is getting the boards made for.
I have Armagdn03 Pulsed DC circuit driver, will that function the same, and I assume a FG will also work well but a lower power level.  Hopefully I could get this explained also so I can get up to speed.  Hopefully this will help others also.  Thanks again Fern
Thanks guys
Sephiroth
Quote from: allcanadian on January 04, 2009, 05:58:30 PM
Tesla hid some very intersting clues in patents not nearly exciting as his magnifying transmitter, some of these patents include therapeutic devices whereby two wires could be connected anywhere on a short strap and a differing potential would develop across the two wires, the potential developed across the wires was based on how close the wires fell to maximum and minimum potentials of a wave form or changing tensions on the wire ----
That sounds familiar...
Video by Karl Palsness on the Energetic Forum
http://www.youtube.com/watch?v=rDWF50fUoYY
maybe not the same patant, but sounds like a similar principle...
