"Smoking Gun" - finally!
Started by PaulLowrance, December 03, 2008, 04:51:16 PM
PaulLowrance
QuoteMostly to inflate the ego by serving postings with bile as dressing. Not the only one in this forum. Please ignore (this posting also  ;D).
Thanks for the good advice. I'll just remind them, on occasion, that they're posting claims void of mathematics.
It's been 14 days since the last diode array measurement. I just took the measurement. I don't have time to post the number with the comment since I'm watching "Whale wars" and the commercial just ended.
Later,
PL
Grumpy
Why does it work a all?  The diode array that is?
There used to be a nice replication of Tesla's Radiant Energy collector on the web - can't find it now but was a nice detailed experiment - successfull one at that.  Showed a nice slow charging of a cap for free.
You could probably see this charge building with a high impedence meter like a VTVM - I'll have to try that.  Energy collected would be related to size of collector and possibly to it's mass as well as it's elevation.
        -Frank Edwards
PaulLowrance
Hi,
It works by rectifying thermal noise that flows in and out of the diodes depletion region. The diode is a dynamic resistor, where the depletion region varies depending on the amount of current. The idea that diodes do not rectify below a voltage threshold is utter nonsense. Any good EE knows full well that diodes rectify at *all* applied AC voltages. Below Vt, the thermal voltage, which is ~ 26mV at RT, the diode square laws is rather accurate, which states that the DC voltage produced by AC is relative to the square of the applied AC voltage.
BTW, you have to be very careful with such experiments because of radio waves. I have spent 12 months now, and have the system down well. Such measurements ***must*** be inside metal shields. I use at least two metal shields. The inner shield is ~ 7". The outer shield is ~ 1ft. Also, the diode array must be compact, no open wires that will pick up external fields.
I've conducted such experiments at countless locations in completely rural areas. In canyons, caves, long tunnels inside mountains. The measured DC voltages are real.
BTW, I'm still typing the big news, after Stargate Atlantis tv show, and it is BIG NEWS!
PL
Grumpy
Place the entire device inside a soleneoid coil connected to DC of 24v vertical orientation - does the "thermal noise" increase?
        -Frank Edwards
PaulLowrance
As stated 14 days ago, tonight is the scheduled 156 diode array measurement. It was the big one, the one that could determine the mystery behind TEDE.
Big news for diode array research -->
http://greenselfreliantenergy.com/forum/index.php?topic=60.0
PL
