Pyramids sort virtual particles using casimir force
Started by froarty, December 05, 2008, 01:13:27 PM
froarty
couple more clues for harnessing limestone -calcium metal  casimir plates, casimir plates will normally self aggregate unless braced apart or formed by chemical action such as leaching after the fact like sodium hydroxide used to make raneynickel  in BlackLight Powers catalyst discovery. In a limestone slurry the cavities will orient themselves for minimum resistance to time-gravity. this means the block should be stood on end so the microscopic cavities present the more resistant profile. In the case of Coral Castle the coral was created by organisms depositing calcium that again took the path of least resistance. the test will be to agitate the block so these molecules drag out as far as possible on either side of the "Present" time frame providing a frictional brake in the vertical gravity-time direction but allowing the block pendular motion in the horizontal.  -Sounds crazy I know but if Dr Mills' hydrino is for real then all the rest follows logical progression! simple test would be a hydraulic jack to lift, agitate the block with moving fields, sound, heat or combo then lower the jack -maybe whole aparutus on a scale to test for marginal results while we dial it in?
TechStuf
The following is a true account of one of my experiences:
http://www.rense.com/general54/babalc.htm
So, I'm with you as far as matter being induced to higher energy states by the right frequency interactions.  I think the evidence is compelling that anomalous gravitic interactions have taken place in various independent 'labs'.  Of course the evidence is also compelling that TPTB have gone far beyond that as a result of such discoveries.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
froarty
don't know what TPTB stands for but I agree it is unlikely to have gone undiscovered for so long -granted you have to have metal cavities <2nm, to produce hydrinos like Black Light Power you need open cavities, to use for friction with the miniscus of our 1 nuclei wide gravity-time frame (Present) you need an enclosed cavity with an excitable gas such that we can agitate a portion of the atms to form "twisted" covalent bonds and then circulate them around like oversized pincusions where the electron -needles are catching a ride on the overall downward motion of gravity -time. I'm thinking maybe still 9.8 meters per second...but NOT squared because you keep starting over everytime the needles prick the fabric.
TechStuf
We conspiracy nuts like our acronyms...lol....it stands for The Powers That Be.  I take it then, you have read Tesla's ideas on the "solidification of the aether"?
TS
froarty
ok, I am not sure if we are talking conspiracy yet- my theory has been emailed to hundreds of physics and some geology faculty all over the world in the last 10 days since I realized the "hydrino" theory suggested by Dr Mills, and two doctors in a May 8 patent from caltech is only a "working mans" theory that allows for chemically rectifying energy from gravity-time flow through the "present" or as CalTech patent explains using casimir force to reduce the hydrogens atoms' zero state below minimum (already extremly controversial).they missed what I think was clear -that atoms passing thru the plates will simply rotate in and out of what they call subzero state and that the atoms must form covalent bond while passing thru the plates to retain what I term"twisted" orientation outside the plates where it can be harnessed as fuel. I agree with classic physics that an electron orbit has a minimum radius and can not become "sub zero" My theory is that they twist on the time axis only appearing smaller from the perspective of normal space. My theory makes numerous unexplained anomalies suddenly fit a plausible pattern. http://www.blacklightpower.com/ in Cranburry NJ has 60 million in investment funds and with their recently validated (oct 25,2008) product by Rowan University labs want to sell us preloaded fuel cells where small amounts of hydrinos are contained in the skeletal catalyst Rayney Nickel and heated in a reactor. the amount of energy released was repeatedly hundreds of times greater than the amount of hydrogen added to the catalyst. they were unable to detect any change or degredation of the catalyst despite repeated cycling over the summe/fall investigation. My point is that anyone should be able to produce their own hydrinos using simple hho kits modified with skelatal catalysts to convert hydrogen to hydrinos - when the covalent bond is cut by combustion the virtual particles act in an organized fashion to push the twisted atoms back into normal orientation - proving that we can chemically force the normally chaotic nature of virtual particles (AKA vacumn flucuations) to organize and do harnessable work. it also proves we are not getting something for nothing -we know that we are moving thru a sea of virtual particles and that these particles must squeeze thru and around all nuclei as it passes from the future to the past on the time axis. black light has simply found a "casimir / chemical: principle to rectify some of this energy. I have made a simple flash animation of my theory here http://www.byzipp.com/animation2.htm - the page has a menu with the proposal, casimir force history, and links to the recent patents and lab validations.
               the additional importance of this discovery cannot be understated, the "open" casimir cavities of skeletal catalysts mean we can "process" twisted molecules to form an entirely new branch of chemistry and physics. the possibility of multiple stage casimir chemistry as the product of each plate appear smaller from our perspective than the inputs of each preceding stage means that super twisted molecules become possible. The "twisted" molecules inside "closed" cavities as I have been explaining offer plausible explanation for legends of coral castle and pyramid block if the calcium metal forms casimir geometry. The trapped gas in these cavities will have a certain proportion of twisted molecules settled into an orientation of least resistance with the gravity -time field. Agitating these molecules caused their twisted dimension to oscilate like oversized pincusions between two curtains (future & past). propped up before agitation the "curtains" would allow for pendular motion but restrict upward or downward motion. The geometry of the pyramids also suggests intelligent manipulation, As the gravity-time field "crosses" the present on the time axis we feel the virtual particles permeate our 1 nuclei wide temporal dimension. from the temporal dimension this 1 nuclei wide fabric folds almost infinetly to trace out what we perceive as reality in much the way an electron beam traces out a picture on a TV screen. this 1 nuclei wide folded mesh implies the pyramid shape is sorting and steering virtual particles like an aircraft nose cone  steers air  around the plane, the larger virtual particles (gravity) are steered around the the casimir cavities through subsequent layers of the pyramid redirecting them to the outside of the pyramid, the smaller virtual particles that normally permeate the nuclei instead of going around and which we experience as time do fit inside the casimir cavities are
allowed to concentrate on the centerline of the pyramid. I would suggest any serious pyramid investigations "close off" the pyramid openings with casimir plates in the form of limestone blocks. an open pyramid corridor will immediately relieve any virtual particle differential, the celesstial observation shafts are probably another clue to VP manipulation that I am still chewing on.
