Magnetic wires as "Free Energy"
Started by PaulLowrance, December 07, 2008, 11:00:55 AM
TechStuf
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
scotty1
Hi all....I noticed the quote from Ed Leedskalnin was not quite right, so I've included the relevent passage below....
"I told you that the coil is a magnet during the time the currents are made.
now I will show you. Get a small paper box to go in between the prongs of the
U shape magnet, put iron filings in it. Wrap six-inch long soft iron wire with
paper. put the wire in box in iron filings, now put the box between the U
shape magnet prongs. Raise the wire up, then you will see filing strands
clinging to the insulated iron wire. Raise the wire up slowly, then the filing
strands will sag and fail, take the box out. put the wire in the filings
again, raise up and you will see that the wire is no magnet. but during the
time it was between the U shape magnet prongs it was a magnet. This shows that
during the time the coil moves through the U shape magnet the coil becomes a
magnet, but its function is double. Some individual North and South Pole
magnets run through the coil's wire crosswise, and some run through the coil's
wire lengthwise.
Maybe you think that it is not fair to use iron wire to demonstrate how
magnetic currents are made, but I can tell you that if I do not use iron core
in the coil I can make more of the magnetic currents with soft iron wire coil
than I can with copper wire coil, so you see it is perfectly good to use iron
wire to demonstrate how magnetic currents are made. You can do the same thing
with the copper wire in using iron filings, but only on a smaller scale."
BTW To do the test the U magnet needs to be bend up, prongs down, N pole prong in compass N, South pole prong compass S. (that's the way Ed had it)
The wire is put in the box with the filings pointing E/W......
This is also to demonstrate why there is zero current in the coil when it is in the middle of the U magnet....but that's another story.. ;D
Mk1
Ed Leedskalnin more details, http://www3.sympatico.ca/slavek.krepelka/exper/magcur.htm
here is explained his view on generating electricity
with soft steel wire ,http://www.code144.com/forum/viewtopic.php?f=2&t=154
http://jnaudin.free.fr/dragone/dragone.htm
The magnet permits to keep the current in the coil and is pulse to activate the flow , I believe Ed used his flywheel to generate the pulse, coil can be also used .
Magnethos
Steve Mark's used in the TPU a "Super Cobalt 404 magnetic material" I think that kind of material is also known as Samarian Cobalt.
Copper is an enemy in the free energy science, Positive energy is the 2nd enemy.
Ed Leedskalnin said that he got more energy using iron wire, than using copper wire.
Doug1
Quote from: resonanceman on December 08, 2008, 03:55:16 PM
The  guy that created Coral Castle  was reported to have said  " I have made lots more electricity  with steal than I ever did  with copper. "   I believe that  the magnetic fields are attracted to iron . ...in theory this attraction  should increase the  energy level a little ........  If I am right about this ......the ideal  wire for OU motors and such might be a  soft iron  wire  heavily  plated with copper.( for lower  resistance .)
gary
Copper plating is not practical but your getting warmer.
