Homopolar Generators (N-Machine) by Bruce de Palma
Started by dtaker, December 01, 2005, 02:55:54 AM
Landor
What Scotty is saying is true both he and I have done simple experiments with magnets and proved this concept.
That is why I am able to make some headway with magnetic power.
scotty1
All the wire testing is from Ed Leedskalnin's notes.....
Ed Leedskalnin said that his best machine uses the winding, or rotation to increase the strength of the permanent magnets......
I have a coil with an iron core and the coil is put in a N/S position. I make the N end of the core a N polarity by running current in the wire.....Now i place a steel tube around the coil and notice that the N end of the tube is a South polarity.
Each polarity is made by the way the currents are running in the wire. The currents are running in a right hand twist and the wire becomes a magnet itself.
Whenever the currents stop then there is no pressure in the wire and magnets from the air jump onto the wire....As they do they become elongated and run in the wire when the pressure is raised again.....though others jump out of the wire due to centrifugal force and crowding......
Light is the product of putting something in the magnets way....and pushing many through it.....It is not the fastest thing.
z_p_e
QuoteEach polarity is made by the way the currents are running in the wire. The currents are running in a right hand twist and the wire becomes a magnet itself.
Are you saying the wire that you refer to (mentioned twice above) is the steel tube around the coil?
z_p_e
scotty1
Ok..i'll use my PMH to demonstrate.....
I have marked the poles of the cores and tubes (actual steel pipes)
All the poles are caused by the way the currents run in the copper coil wire.
If 1 end of the tube be joined to the core, then you have a stronger electromagnet still.
Interesting to note, my pmh can sustain its own weight even with the steel pipes on it......indefinately!
The keeper is a laminated transformer core.
z_p_e
I don't remember where I got these pics from, but it looks a lot like the item in your last post. As I recall, the description of its capability to store the energization indefinately, also sounds very familiar.
z_p_e
