Homopolar Generators (N-Machine) by Bruce de Palma
Started by dtaker, December 01, 2005, 02:55:54 AM
scotty1
Hehehe......you see i wrote....it's a trick i learn't....
All the voltage is from the mains gremlins.....they get into all my tests so i thought i'd show people how it works....it can run a small load like LED but that's all...
I do see however that i could induce alot more with a good setup, and store the energy.
The main test i was doing was with the coil with 3 windings.....In a normal coil with an iron core, the core only gets 1/2 of the magnets it could get from the coil wire..the other 1/2 is wasted as it goes on the outside of the coil wire...
The (pmh) only has an extra catch if you believe that there is 2 magnetic particles that govern all matter......
"All that has to be done is to start the North and South pole individual magnets in an orbit and they will never stop" Edward Leedskalnin.. "It demonstrates how all magnets are made" E.L  "It (the pmh) has little power but could be made stronger by making bigger dimensions" E.L....
"U shaped magnets have a broken orbit, but under the proper conditions, it is permanent." E.L
HMM
Hey,
Did anyone try putting two perpetual motion holders together and energize them at the same time?
Mike
Neologic
A previous post by someone who visited Bruce said that the "N" machine was a 'dead horse' and did not achieve over unity.
Bruce claimed that it was possible to achieve over unity with the "N" machine. Here is a quote from a popular site:
http://www.keelynet.com/energy/centrifuge.htm
"On the basis of his above discoveries, dePalma invented his 'N-Machine', which has over 330% efficiency, i.e. it produced 230% of free energy, in independent tests!"
I spent about a week with Bruce in 1991 and then about 6 weeks with him in April and May of 1992. The month of May we (Bruce, Andrew and myself) were in Australia. Interestingly enough, we left LA International airport the 3rd day of the LA Riots. Was odd seeing all those plumes of smoke from burning buildings...
Attached is a picture showing Bruce, Andrew, myself (on the right with the "Indiana" hat on - I still have that hat and light jacket). The two in front are Claudia and Paul. We stayed at Paul and Claudia's house for several days before continuing on our 'journey'. BTW, the picture below has never before been previously released to the public, it is from my private album. The picture was taken in Brisbane, Australia. Even though it was May, it was actually the cooler season for Australia - hence the extra clothes we had on.
Bruce had different concepts in regards to the physics of our universe. He specifically believed that energy IS created and detroyed and does not change form. That energy can be derived from the stresses caused in space, such as those caused with magnets. Simply put, when you cause a stress in space, energy is there to be released, used, etc.
The biggest problem with the final "N" machine built, was that it was constructed with magnets that were hexagonal in shape. Simply put, the magnet disc (or pie as it was referred too) was actually a conglomeration of hexagonal shaped magnets that were glued together. The 'problem' was that at higher RPMs (which is important to achieve) the unit had vibration problems and further acceleration of the unit was not possible without the possibility of the unit tearing itself apart. The "N" machine by all means DOES produce electrical energy. EVEN IF the "N" machine does not achieve over-unity, then a very important consideration is that the "N" machine shows a barely measureable slow down when a load is applied. In the demonstration I witnessed, a rather large (about the size of my body) resitive load was applied to the generator and while it produced a measureable slow down (induction I beleive?) it was not significant and compared to coil-based generators is significant in it's efficiency (at the very least).
Today, you can purchase neodymium magnets of various shapes and, if manufactured well, should be quite balanced and higher RPMs would be achieveable - hence the test for "over-unity" is now possible - whereas it really was not when Bruce built his last prototype. The data collected with the final unit had shown the potential for over-unity. There was not reason to expect a plateau of the energy being drawn from space.
Even if you only considered the amount of energy IN space - emitted only by the sun - there exists incredible amounts to be harnessed. This isn't really even considering the possibility of zero point energy concepts.
At the time I wasn't as interested in the "N" machine as I was more interested in 'solid state' power supplies (think Moray, Radiant Energy, cold fusion, zero point, etc..). However, the "N" machine should not be thought of as a 'dead horse'. The "N" machine is doing something that other devices could do, it's just something that people can relate to easier.
Sadly, Bruce died several years later in New Zealand. I came back the US about the time Andrew and Bruce decided to go to New Zealand. I fully expected to travel to New Zealand to see them again and received several more pictures with requests to get my butt back over there. I regret not making it back sooner. I believe Andrew made his way back to the US and I'm not entirely sure what he is up too these days. I hope he too is doing well.
Best Regards,
Robert - aka Neologic
tishatang
Hi all,
I just discovered Tesla had patented a design for a unipolar generator.  May have been missed all these years because it is titled "Dynamo Electric Machine".
Look up patent #406,968.
He cleverly ganged two with reverse polarity together with steel belt, the belt eliminating the need for brushes at the outer high speed edge, with the power output only at the slow moving inner brushes.
Tishatang
