Homopolar Generators (N-Machine) by Bruce de Palma
Started by dtaker, December 01, 2005, 02:55:54 AM
gravityblock
Quote from: gravityblock on March 16, 2015, 01:21:18 PM
Mags,
In the pendulum test, you could also place a conductive material that covers a larger area underneath the magnet that isn't part of the cicuit.  There should be a gap between the magnet and this additional conductive material.
Thanks,
Gracock
Try this test with both a solid connection and without a solid connection.
Gravock
gravityblock
I'm thinking about a cresent shaped conductive material that either surrounds half or most of the conductve magnet in a diametrical configuration.  This may allow us to design a brushless motor without an induced net emf.
Gravock
gravityblock
Quote from: gravityblock on March 16, 2015, 01:56:31 PM
Gravock
Could this concept be similar or related to the notched objects observed in NASA's failed tether experiment.
Gravock
gravityblock
Broli,
I'm not sure if you're still following this thread or not, but wouldn't a conductive material that partially or mostly surrounds the rim of the magnet and is electrically isolated qualify as the open circuit we have been looking for?  I don't see why not, and I would love to hear your thoughts on this.
Thanks,
Gravock
Magluvin
Quote from: gravityblock on March 16, 2015, 12:53:23 PM
Mags,
You may be partially right.  In your initial experiment, there is more conductive material underneath the magnet than there is above the magnet, and this could cause an unequal breaking force between the top and bottom edges of the magnet, similiar to this video showing how a magnet will find the center of its own way on a conductive path,  https://www.youtube.com/watch?v=d4KKeA3RI98
Please let me know what you think.
Thanks,
Gravock
Well, like I said earlier, the foil floor is not the usual path for current to flow like a wire. There may be some push and pull for all I know. There may be possible upward push, levitation, etc.
But thinking about it more recently, the foil seems to be key.  lol, what might be interesting is if we have a panel with foil on top also. Would the mag move still? Or would that want to make the mag move in the opposite direction, negating the original effect? That may be simple to do also. Would be neat if the mag shot forward and out of the foil sandwich. ;D The top plate could be very thin plastic to mount the foil, like a larger piece of bubble pack that products are sold in, as to not have too much weight on the mag keeping it from moving. ;)
Ok. Gunna start working on the film test.  In your post showing the foil under but no electrical connection, Im not sure the foil would help being there or not. Might even slow things down due to lenz.
Mags
