Solid State Bedini Charger - Easy to Build
Started by supermuble, December 14, 2008, 11:17:16 PM
supermuble
Hi guys, just a follow up. I noticed this article is still here, and it's been 4 years, that's the beauty of the web! Everything you type stays forever.
After countless tests I came up with a very powerful radiant charger called the HHO Pulse Charger V2.0, it uses off the shelf parts. Take a look at my youtube videos to see it in operation.
Search for HHO Pulse Charger V2.0
Or visit my webstore click here for instructions. http://ritalie.com/store/index.php?main_page=product_info&cPath=9&products_id=14
Magluvin
Hey Super
One thing you can do to improve your 'sales' of PDFs is to give more details in your vid.
Theres probably one detail that was incorrect. The 10 diodes in parallel are really the opposite of the HV diode from the microwave. The microwave diode has diodes in series to increase the 'Peak Inverse Voltage', but the amp rating is about 1 amp, about equal to one UF4007 diode. Your 10 diodes in parallel have a bout a 10 amp rating as a whole at 1000v PIV. The microwave diode is in the range of 9KV PIV but still only at 1 amp. In the microwave transformer, the the diode is used on the secondary, the winding with the fine wire and many turns.
So the MW diode can be used in place of the single UF4007 and probably be a better choice as the secondary voltages of that transformer(if the input is 120v) can be near or even over 2KV. The UF4007 is only 1KV. Or you can use 2 or 3 in series to increase the PIV to 2k or 3k, just to be safe. ;)
Ok, back to the more details....
I see that you are not 'fully' describing the circuit(schematic, etc.), otherwise people wont need to buy your PDF for $20.
But without some important details, like what is the input consumption of the device vs the quantity of gas produced.  These things wont hurt sales or give any secrets.
Also showing such a short run time is a bit discouraging. I dont think Ive ever seen a run time as short in vids of HHO.   ;)
tarcius
here is some plans that i bought and willing to share with everybody.
In pdf u have plans for simple solid state bedini circuit.
(admin: Removed due to copyright issues)
baroutologos
Radiant power! How lovely does it sound. Actually, almost any newphy in the OU quest starts with Bedini's contraptions and fancy terminology and with the correct dosage of conspiry theories tend to be mystified by simple facts that an experienced in the electric/electronic profession can hardly be amazed.
Bedini's radiant chargers are nothing more that pulse chargers that exhibit desulfating properties (they are many better desulfators or battery rejuvenators than Bedini's as the AC desulfator ) hence rejuvenate old batteries.
Sorry but cant help it. Every time that i see, radiant this and radiant that, a smell a book seller!!
Cheers,
DomiChi
Quote from: jadaro2600 on January 22, 2009, 12:17:31 AM
Terrorists beware!~
;D
Now, what exactly is a Bedini machine anyway -I've hear these rumor's that the machine is a hoax.
Look at http://rpmgt.org/JoinBediniList.htm. If it was a hoax they certainly not propose help to get it working.
