Solid State Bedini Charger - Easy to Build
Started by supermuble, December 14, 2008, 11:17:16 PM
Quote from: DomiChi on March 17, 2013, 06:24:17 AM
Look at http://rpmgt.org/JoinBediniList.htm. If it was a hoax they certainly not propose help to get it working.
Rather depends on your definitions, doesn't it? Certainly Bedini's various machines "work". And just as certainly... nobody, nowhere, including Bedini, has ever gotten any free energy or overunity performance from them, in spite of all the years, all the variations, all the "replications" and all the claims.
They are fun to play with though, and they can temporarily restore sulfated batteries, but I'll wager that they have killed more batteries than they have revived, all total.
morfes2
Quote from: tarcius on February 22, 2013, 01:57:13 PM
here is some plans that i bought and willing to share with everybody.
In pdf u have plans for simple solid state bedini circuit.
hi
i want to thank you very much for your file. keep up
Mo
Once you set up your solid state charger there is an easy way to measure its average output power.  Simply replace the charging battery with a large capacitor in parallel with a variable or fixed resistor.  Run the charger and measure the DC voltage across the capacitor after everything stabilizes.  So the average power P = Vsquared/R.  If you choose a large enough capacitor and the right resistor then you might see a stable voltage say above five volts and less than 100 volts.  If you change the resistor value the capacitor voltage will change and your power calculation will remain approximately the same.  You must be careful not to over-voltage a large electrolytic capacitor.
Once you have measured your average output power then you will know how much energy that you have put into the charging battery over a certain period of time because energy = average power x charging time.  Also, you can measure the pulsing frequency and then derive the energy per pulse going into the charging battery = average power x pulse period.
If you are a real keener then you can charge and discharge your batteries and measure your energy put into the battery and compare it with the energy that you can get out of the battery.
Suppose you take a guess that your average output power is 5 watts.  Let's assume that you have a 20000 uF 50-volt electrolytic capacitor.  If you use a 500-ohm resistor the V = sqrt(PxR).   So the voltage will be about 50 volts.  That's the borderline voltage for the capacitor, so let's change the resistor to 400 ohms.  Then the capacitor voltage stabilizes at about 44.7 volts.
If you are going to make a guess that the average output power is 5 watts then you need to make a 5-watt resistor.  You might have some 1-watt resistors hanging around to do that.  For example, five 2K-ohm resistors in parallel will give you a 400 ohm resistor.
The RC discharge time constant for the capacitor in parallel with the resistor is 400 x 20000E-6 = 8 seconds.  Therefore, if your pulse frequency is about 1 Hz, the 20000 uF capacitor in parallel with the 500 ohm resistor will act like a good smoothing filter and the voltage across the capacitor will be DC with a small noticeable ripple.  If your pulse frequency is 10 Hz or faster then the voltage across the capacitor will be very close to pure DC.
casstete
Quote from: MileHigh on March 19, 2013, 12:05:14 PM
... blabla bla
bla bla bla bla .
You guys are jokers , you suppose to be Hero Members and you have no clue about what radiant chargers are doing and where they are drawing the power AND YOUR FIRST SENTENCE PROVES MY POINT !
If you think you can measure the accurate output or COP from a Bedini charger with a capacitor you have no idea how it all works .
But you have loads to say about radiant charger like the other "Hero Member"
The COP is in the Battery ... and it CAN NOT be replaced by anything except for
Living things , Water & maybe nano crystalline materials
a.p. Bedini nothing but Lead Batteries ! And without these Batteries you DON'T GET OVERUNITY !
Shouldn't be too hard for all you "specialist" .... "Hero Members" to actually TEST !
Don't look for the output from the Chargers ... look at backend .... how much can you draw from Batteries vs input .
Not Rocket science & you don';t need much electrical engineering skills just tools , time and a hand full of $
casstete
Quote from: morfes2 on March 18, 2013, 08:20:22 PM
hi
Mo
I know supermuble and he is a excellent guy that spend years on developing his device with countless parts burning up & needing to be replaced .
Tarcius is a dick & copy right infringing . File should be removed & user banned .
Punks will not download Torrents cause they scared by upload files by honest hard working simple guys ... trying to understand what you people never will cause you to ignorant and all the posts here prove it .
I mean you don't even understand that the overunity comes from the way the cells in the Batteries react and how they absorb energy from their environment .
AND BEDINI SAYS IT SO MANY TIMES .
NOOO you have Hero Member suggesting CAPACITORS .... MUAHAH ... come on guys you not serious or you work for GE trying to Bullshit the rest of us honest people !
CAUSE Supermuble is so honest he has been giving the 90 day moneyback guarantee to punks like Tarcius .
Funny thing is they still way to thick to build them however simple they are !
