Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Yucca
Hi Jesus,
A small reed switch with resistor should work fine to supply the drive signal for the motor coil, just like a regular Bedini build.
But I plan on using a 5V logic line from a microcontroller (UC). The UC will have a hall effect sensor next to the rotor. By doing this I will have accurate control over the pulse timing and pulse width. Also the UC will be able to display the RPM, timing and width angles on a tiny screen.
I have included a week old photo of my pulsemotor build, it has progressed alot further since the photo, I am just finishing all the wiring. I will post you another photo here in a few days. You can see a reed switch at the top but I will be replacing with hall effect sensor for more accurate position signal.
I will probably try the BEMF recycler circuit in a week or so when I have the motor running with the UC. I have ran the motor just using the reed switch to pulse the coil but I´ve nearly killed my reed switch.
yucca.
nievesoliveras
Quote from: Yucca on February 12, 2009, 04:33:22 AM
Hi Jesus,
yucca.
That pulse motor looks great!
The coil seems built U-shaped. Is that correct?
About the switching. I think that the best one is the Bedini's original transistor trigger with the bifilar coil. But if you think that with a hall effect switch you will get better position accuracy, go for it.
Jesus
Pirate88179
@ Yucca:
Nice build there!  I'll bet that is going to work well for you.  Excellent job.
nievesoliveras
Hi! @pirate
@all
I made a secondary coil on a JT toroid, with a coil cable from a discarded phone charger.
I tried it first alone and tried to get some output reading, but there was none dc or ac.
I connected it to the pulse motor and with a charged 1.5v battery it run the motor.
When I connect a red LED to the circuit, the LED lights. Not too bright though.
The Idea is to connect the secondary through a rectifier to the source battery to see if it gives any feedback to the source.
I need to add some terminals to the secondary thin wires in order to connect it to the breadboard.
I have noted that each time it is harder for me to do any tests.
Jesus
Yucca
Hi Jesus and Bill,
Thanks, I´m enjoying building this. A half hour here an hour there.
The peculiar coil is the idea of a user called @woopy called the DEK UCC. DEK is the name of his pet dog and UCC stands for U shaped Coreless Coil.
A normal coil produces a field like this:
N S
The UCC produces a field like this:
N S S N
UCC Thread:
http://www.overunity.com/index.php?topic=6727.0
I want good positional accuracy because I want to fire the coil with a very short high power pulse just
as the magnet goes through the centre of the UCC coil. But I agree the bedini bifilar is a very elegant and efficient method. One coil that I will definitely be winding for my motor sometime.
