Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
nievesoliveras
@all
I will not make you suffer. It is a pleasure to share this information.
But before I have to explain the heart of the circuit.
The toroid: It is a medium toroidal ferrite from Electronic Goldmine. Part # G6683 Pkg of 5 $1.00
The primary wire is an aluminum covered strand that is bifilar from a computer cable with the number:
AWM E101344 Style 2990
The secondary that is optional, is 30 AWG magnetic wire
The Pulse motor transistor is 2N2222
The Joule thief transistor is 2N4401
The Diodes are 1N60
The optional rectifier is a G1113 from Goldmine
Both the resistors are 100 ohm
The capacitors one is electrolitic 2200uf 50v
The other is ceramic 473z 25v
The potentiometer is 10k
There is a neon bulb and a red LED on the Bedini circuit
The Newman coil has two coils of 700 turns each of 30 AWG magnet wire
The diode comming from the pulse motor circuit is not used. If connected the motor stops.
I do expect that everybody can make a successful replication!!!!!
Jesus
plengo
@ nievesoliveras
great work man.  Now, forgive me to ask a little bit more. Can you post a fresh picture of the setup and show where the charging batteries would be connected?
Many thanks,
Fausto.
Yucca
Great news Jesus, congratulations! The results sound very good.
nievesoliveras
Quote from: plengo on February 20, 2009, 02:32:06 PM
@ nievesoliveras
Many thanks,
Fausto.
@plengo
I have to get some courage to disconnect the charging batteries from the circuit and take some photos. I am afraid that the motor stop and never again work. As the fan charger I built last year.
When I got the courage to stop the pulse motor I will take some photos. Or wait till I can buy some new batteries and leave that motor running without disturbing it.
It is that is so fulfilling to see the motor with the charging batteries slowly fluctuating between 4.43 volts and 4.49 volts while keeping the source parallel batteries fluctuating between .35 volts and .36 volts.
On the meantime be pleased with this schematic with the charging batteries on their right place.
By the way, the photo maybe will not be that sophisticated, it is the same motor with some changes on it.
I will read the camera instructions to see if it can be used with the computer to take photos without having to buy a new pack of batteries.
Thank you to all well wishers !!!
Jesus
Mk1
Congratulation!
You are a hard worker , and you did a great job! Some would has stopped way before , but not you , real good you did and shared all the way , Good bless you , my friend!
Mark
