Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
gadgetmall
Here is a Smaller Battery Switcher Which Uses Less Parts . I will Try To integrate it into the Newman and Bedini Jt  for An extra battery to do extra Work . Ie . Lights  Backup  , run another motor  or just to have a few extra batteries always Charged .  I have found a piece of Pipe . And have the Toroid Wound . So Next step is Cut it and Wind the Newman . . I always wanted one :) !
I Find Myself a little tired of the Nonsense in threads that is meant to hinder ones work than help . I apologize because it not my thread but i know you have worked hard and went thru a lot of electronics to get where you are right .
I think your Getting a Genuine BEMF Positive Charge . That is VERY Good !! . Now All were need to do is boost it with some caps .have you tried this setup . I show you on your schemitic below  I see you did not connect your Bridge negative up ? r .
gadgetmall
or even Better as this wont interfere with your motor . Isolated Charger ?
Koen1
Yeah, that may not be a bad idea at all, to seperate the charger side
from the rest of the circuit. :)
Thanks Gadgetmall, you sure are a great source of handy circuits ;D
best regards,
Koen
Low-Q
Quote from: gadgetmall on February 22, 2009, 04:12:36 PM
You got a lot to learn . Forget your Calculations  . Bemf  IS voltage Amps and TIME
And all of our designs that self runs uses a Buffer(Battery ) as Newman and Bedini as well  like Jesus and i . Its a fact Please Build your own  a working model yourself Prove it to yourself . We prove to ourselves , give you the plans . Make your own and see . This is why a post like yours offends us and we care not see post such as yours . Never come to someones Forum's thread  with Negative Attitude and  start explaining how to measure this and that  about equations you have no idea  to include the Space Time calculation besides just amps and volts . It don't work that way .to use on an overunity or unity device.COP1 :2  you build it YOU WONT KNOW and therefor Have no Right at all to Criticize the great work done here Especially when others have already duplicate and do have the right to offer help .
. .When you get to Our Level Of success you will also Scream EUREKA !!! Don't Spoil it fo other just because you cant understand it and want proof to be shoved down your throat :) Its here already read !
regards
Gadget
No offence, guys!
I am really sorry if I have offended anyone, I truly am! But shouldn't it be possible to question both your statements, results, and the Newman-motor itself? You all hopefull guys MUST take into concideration that someone allways will question your work, and the results. My link was also a link to a guy which was mislead to believe he could make more power than he used. This is a story of a man with several designs, and trials - all of them failed. He has spent lots of dollars on his project for nothing. You should sure respect those experiences as well!
I think this thread is going a little bit out of hand. However I whish to state my views, and share some infrmation, guide people with the help of some common theory and practical experimnts. If a blind man is walking with his stick towards a steep cliff believing that he is walking safely, wouldn't you try to guide him in another direction? At least tell him a few hints that this particular diection isn't doing any good? OK, I know this is just theory, so maybe that man knows that the power of space will help him walking in thin air? And sure he well walk in thin air - but just for a while. For sure he will stay in the air for quite much longer time with a parachute - WHAT AN ACHIEVEMENT! And then, by help of his friend, he will post his achievements on YouTube. No offence!!!
I understand Jesus, and how he works hard to obtain something with his Newman motor, but nothing in the design can tell me anything about the possibility to OU, or ability to charge a battery pack to more CAPACITY than it takes from the 1,5V AA cell. It WILL charge more than the 1,5 volts, but I'll explain why later in this post.
The switches for the motor itself helps generates high voltage every time the switch is turned off, due to the fact that you are rapidly turning off the magnetic field in the coils. The charge you then get is a result of built up magnetic field in advance by the 1,5V AA cell. I also believe the amps is quite high in a moment too - much higher than continous drawn from the AA cell, but the TIME that high power output is lasting is extremely short. As you stated. It is about amps, voltage and TIME.
We must focus on the net work done in the circuit. 1 watt (U x I) in 1 hour (TIME), do the same work as 3600 watts in one second. I know physics quite much more than well enough to make a statement, but ofcourse, I do not know everything.
I will try to be more open minded regarding the "impossible", but you guys should also be more open minded to the "possible".
Br.
Vidar
nievesoliveras
Quote from: gadgetmall on February 22, 2009, 09:44:21 PM
It does not use the rectifier negative connected because when I did it lowered the rotor speed a little.
By the way the thirteen turn secondary was meant as  feedback to the 1.5v battery. I found that it did not work as expected and connected it to the charging battery. That is why is optional.
To use it as a charger perse, its output voltage should exceed the battery pack voltage. So the turns must be made in order to obtain an output of  7v. But because the toroid outputs 38v, you can use that secondary for other purposes.
Your battery switcher looks simple, but I still dont understand how will it be implemented. It seems an 555 IC with a single post double through relay. Is that correct?
Jesus
