Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
jadaro2600
So, the copper acetate has become somewhat of a mystery.  Adding more hydrogen peroxide to the vinegar results in less crystalization of the copper acetate.
I was planning on using shrink tubing to create a graphite diode with copper acetate as the oxide for the carier.  It would be nice if I could get the crystals to become more solid, they seem brittle.  I had a few that were easy to see, easy to pick up and look at and were approximately 1/8th of an inch or so , however they crumbled rather easily.
I'm going to start a new solution and add only a little hydrogen peroxide so that the formation of peracetic acid is lower that what it is now.
More updates later.
nievesoliveras
@jadaro
Good luck with your experiments.
I think that if the crystal is brittle and you are using shrink tubing, anytime you accidentally bend the tubing the continuity of the crystal may be lost.
Jesus
nievesoliveras
@all
It seems that something is missing on this circuit.
I have not been able to make it work as the logical circuit reading stated.
Maybe it is better to build a reed switches commutator to activate the transistors.
One reed switch should activate first, then the other in secuence.
But what I wanted was to make it as simple as possible with just one transistor as the switcher trigger.
Jesus
nievesoliveras
@all
Still studying. Here is another circuits composition. Logic circuits.
Jesus
nievesoliveras
@all
Here is another group of logical circuits. I am almost sure that the answer lies on these circuits.
Jesus
