Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Groundloop
Quote from: nievesoliveras on April 09, 2011, 05:27:26 PM
Thank you @groundloop!!!
By the way I bought last year among other boards, a Pickit2 from Microchip.  I just have to give it more study time. I find very dificult the assembly programming language used.
Jesus
Jesus,
Yes, assembly programming may look difficult at first. But after a while you will learn to love it because
you have full control of the code and the code will be very compact and fast. And as the time goes by you
will have many subroutines that solve different problems so you will start copy/paste those. There is also
many code examples to be found on the web. Download the PIC16F88 data sheet and you will be amazed
on the things you can do with a micro controller. Start out easy, get some LEDs to blink and go from there.
Groundloop.
nievesoliveras
Do you have for sale an already made board with the pic16f88 already on it?
This are most of the parts needed for all the experiments:
Newman Motor
PVC Pipe 3 to 4" Diameter
Bearings
Threaded bolt 1/4"
Security nuts
Big Magnets
Epoxy
30 to 26awg wire
Enamel paint
Plywood board
Protoboard
Tip31A
Led
100ohm
Neon
2200uf electrolitic
LT1073-12
1N5818
47uf electrolitic
120uh Inductor
0.1 to 0.47uf ceramic
100 to 10,000uf electrolitic
100 Turns of 0.45mm and ferrite
Ferrite toroid transformer - 100:1
Ferrite toroid transformer - 60:1
Ferrite toroid transformer - 43:1
Ferrite toroid transformer - 36:1
1n4007
Velleman flip flop kit
AN28 Opto Isolator
NPN Transistor
Pic16F88 Microcotroller
Board with 32Mhz Xtal
7805 regulator or 5v power supply kit
AQV252G Solid state relay
2N2904 NPN Transistor
555 IC
10uf 100v Electrolitic
Neon bulb
10ohm
1kohm Resistor
2kohm
T106D Scr
IRF510 Mosfet
0.68uf 250v Mylar
Jesus
Groundloop
Quote from: nievesoliveras on April 11, 2011, 08:58:48 PM
Newman Motor
Bearings
Threaded bolt 1/4"
Security nuts
Big Magnets
Epoxy
30 to 26awg wire
Enamel paint
Plywood board
Protoboard
Tip31A
Led
100ohm
Neon
2200uf electrolitic
LT1073-12
1N5818
47uf electrolitic
120uh Inductor
1n4007
AN28 Opto Isolator
NPN Transistor
555 IC
Neon bulb
10ohm
1kohm Resistor
2kohm
T106D Scr
IRF510 Mosfet
0.68uf 250v Mylar
Jesus
Jesus,
Let me first say a couple of words about the Ferrite toroid transformer. That one you can
wind yourself. I do not think you can expect to find ready made transformers that will fit
the specifications you need.
I do not sell anything, sorry. But I have a prototype board I can send you for free. :-)
Just PM me a snail mail address and I will send this board to you. I reckon you are able
to solder? You can find a 32KHz crystal on an old computer boards. It is a small round tube with
two wires located around the computer board back up clk battery. Attached is a image on how
that crystal looks like. So if I send you the board then you will need to unsolder the 16MHz crystal
and solder in the new 32KHz crystal to the correct pins together with two ceramic capacitors.
But before you do that, use the board as it is! Learn how to program the PIC16F88. Then later on you
can change the crystal if you wish. The prototype board will run fine from a 9 volt battery. It has a LED
on it that are fine for testing. It also have a RS232 serial D-sub connector for communicating with a PC.
I can help you with the assembler code to get you going but don't expect a life long support. LOL
Attached is the circuit drawing for this board. The board has two edge connectors, one is for the 9 volt
battery, the other is two outputs for controlling stuff. The output is 0 or 5 volt at max 20mA. So it is
enough to control opto-couplers etc. The RS232 uses a strait serial cable between the card and the
comport on a PC.
I will load the PIC16F88 with a program before shipping to help you on the way. This program will
communicate with a PC and will allow you to switch the outputs on and off by menu choice. This
program will be the starting point for you to learn how to program the micro controller.
But give me a couple of days to write that program, OK?
Groundloop.
nievesoliveras
Thank you @groundloop!!!!!
I will pm you my snail mail.
Jesus
Groundloop
Quote from: nievesoliveras on April 12, 2011, 07:11:59 AM
Jesus
Jesus,
Today I found a 32KHz crystal and has soldered it to the prototype board.
So now you can select from software if to run from the 16MHz crystal
or from 32KHz crystal. I will write some software to test both crystals.
Will make the software soon and test on the board and then ship it to you.
GL.
