Feedback To Source
Started by nievesoliveras, December 21, 2008, 11:28:28 AM
Thaelin
Hi Jesus:
    You may wish to look into the three phase wind gen head setups. I have a small one
that has six coils and eight magnets set up in star config. That makes two coils in series
per phase with one end of each set terminated together. The remaining ends go to a
three phase diode set up made up of one amp diodes. Does fairly good considering what
it is. Put a cap on the output of the diodes and hook it up to a motor, you have the self run
setup. It may be a balancing act to get the right combo, but I think that will do better.
   Using this setup you will eliminate a lot of the cogging effect. Take a piece of paper and
draw out the coils vs magnets and you can see how they interact with each other. Just
remember to put the magnets NSNSNSNS .
thay
guruji
Quote from: nievesoliveras on March 08, 2009, 07:56:45 PM
@all
Here is another circuit that I am testing for a feed back to the source. It makes the source battery to last longer,
Jesus
Hi Nievesoliveras did you check that circuit that you've said so that I can replicate it?
nievesoliveras
Quote from: robbie47 on March 10, 2009, 10:31:31 AM
@jesus,
It would be better to start a separate topic on this.
Thank you @robbie47
I think that I will do that as soon as my internet connection gets stable. It is a little crazy. It works when it wants to. It is not reliable at this time.
Jesus
nievesoliveras
Quote from: Thaelin on March 10, 2009, 03:31:02 PM
Hi Jesus:
thay
Thank you @thaelin
Could you make a rough sketch of what you propose?
Jesus
nievesoliveras
Quote from: guruji on March 10, 2009, 04:45:15 PM
Yes @guruji
I tested the circuit and it last longer than a regular one.
Jesus
