Flywheel powered by magnets and gravity? Need ideas.
Started by magnetman12003, December 28, 2008, 07:37:30 PM
magnetman12003
Hi All,
Here is an idea I am considering right now.  The distance areas marked with a question marks are critical on the illustrated diagram. Depends on what you are using for ring magnets
In my case a huge floor ring magnet and a smaller ring piston magnet offset at 45 degrees that faces the floor magnet under it
Position #1 starts the whole chain of events. (The flywheel is rotated by hand clockwise to start motion.)  The lightweight but powerfull piston magnet/rod assembly at this position just starts to lean into and slide "UP" the repel force field generated by the floor ring magnet.
The piston magnet then starts to repell upwards pushing on its rod which in turn drives the offset flywheel crank clockwise.
Position #2 shows the piston magnet at the half point in its up travel.  Even if the repel forces are less at this point the inertia of the flywheel spins the lightweight piston and rod up and over top dead center.  Thats position #3.
From position #3 to position #1 is all down forces by gravity.  Then inertia of the flywheel repeats the whole thing.
Need input as to why it will or wont work.  Has anyone acually tried this as illustrated?
Tom
magnetman12003
Hi,
I am actually making progress constructing this device. I am using a 9 pound  7.5 inch diameter flywheel mounted onto quality ball bearings and all turns just by finger touching the flywheel.
Notice when the flywheel is offset with regards to the large floor ring magnet the piston rod will ALWAYS push upwards on the flyweel crank starting in the #1 position until the #3 position is reached. Care in distance positioning both the large floor ring magnet and the piston magnet have to be taken. Thats why I have a question marks on the diagram. You would have to experiment with distances depending on what you use for ring magnets
Not illustrated is my centering rod with sliding ring to allow  the piston magnet rod to move up and down and sideways. No fore and aft motion is allowed.
I am going to use a 7.5 inch diameter floor ring magnet and a 3 inch diameter ring magnet offset by 45 degrees.
Why 45 degrees?  Hold a small ring magnet over a larger ring magnet with SAME repelling polaritys  facing each other. Then turn the smaller ring at 45 degrees and bring it in sideways to the larger ring magnet. Notice how "EASILY" the smaller ring magnet slides upwards on the larger ring magnets repelling flux field.  Enough said.   ----- Movie clips will follow boom or bust.-----
Tom
magnetman12003
Here is something that can replace a flywheel piston.
Construct a small flat board and set a bunch of small magnets in it with arrowhead outline holes drilled as per the jpeg below.
All the small magnet polaritys face the similar repel polarity of the large  floor ring magnet.
Now mount the entire board at 45 degrees with respect to the large floor ring magnet on the piston rod.
You will see exactly how easy the repelling tip of the arrow slides into the repel field of the large floor ring magnet.
By the time the arrow head is all the way inside the flux field of the ring magnet the  entire arrowhead studded board is all the way "UP" riding on top of the flux field of the lower large ring magnet.
Give it a try in event you dont have a small ring magnet to use for a piston magnet.
Tom
Bump.
Got it working yet?
And what happened to that other motor that was certain to work? The square SMOT?
magnetman12003
Hi,
The square SMOT idea went nowhere "BUT" I have completed my 9 pound flywheel powered by magnets and gravity and am testing the device right now.  I did not use the large floor ring magnet to power the piston magnet in the UP stroke.  To many problems. 45 degrees did not work out either. Constructed something much better and guess what?  It works.
I am not going to patent the device as you cant patent a perpetual motion machine or device.
What I am going to patent is the concept I used to levitate ( UP STROKE) my heavy piston magnet. I found a powerful way to do just that.  I have not illustrated this to anyone or posted it anywhere..
A lot of folks thought I was crazy and bailed off of my ideas so I quit posting to see if anyone was interested enough to keep in contact with me.
Will post more after I aquire a patent then I will illustrate a working device on syndicated TV and see how it goes.
Tom
