Natures Perpetual Wheel
Started by FreeEnergy, December 15, 2005, 05:23:25 AM
lltfdaniel1
because the bar must weight almost exactly to the main body (as the main bodys weight is spread) the bar is concenrate and thus hits the unbalanced force , and which makes it more un balanced and causes it to SPIN MUCH FASTER.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
because if it was HEAVY Then the unbalanced force wouldnt out match the heavy, so it must all be very Simular in weight (grams or miligrams)
it doesnt matter wether its 10 tons it still have to equal very simular in weight.
lltfdaniel1
i think makeing One of these Out of Plastic would be great as a tester and it would be cheap to , and useing it to experiment.
the flow of weight has to be right ;-).
so the 90 bars have to fit properly on the size of the main body , (whatever that is)
(u know what i mean). Measurement calculations.
because when you start it , the weight goes to the unbalanced ball and the unbalanced balls speeds up the main body and since the main body weights more then the ball it weights more heavy due to spining and that heavyer force makes the BALL MORE UNBALANCED.
This motor works people.
unless yr blind as a bat.
lltfdaniel1
actually Thx Guardian Of Divinity - God , he helped me. (the Source of everything)
does that make sence to you guys now ;-).
as for the bars ( the lines that connect the 2 parrelle bars..well )
thats something to experiment with.. that is what distuributes the gravity power.
it doesnt matter to much if it aint perfect but both sides have to be the same to.
and that gravity power hits the ball at 45 degrees.
(ever watched discovery when the russian liner flys at a constant 45o and every body experiances No gravity??)
actually for the bars , they work like FLUX Lines .
it doesnt matter wther they are 1cm long or 3 cm long as long they are equal both sides to disturbute gravity power.
id go with 3cm.
IN THE HELIX PIC It seems they use a pattern, well its good to Experiment, try 1 line each 3cm ( get it equal depending how long the slopeing bars are.)
lltfdaniel1
Thx God for the Spiritual Food , Not me.
(Oil of understanding)
to get You guys thinking ;-).
don't work with the right side of your Mind, Listen to the left side ;-).
