100% energy saver in the market
Started by gigawattgratis, December 31, 2008, 05:55:18 PM
hartiberlin
A great new Power Saver is the one here at the border or footer ad.
This also gives you 300 US$ tax credit and it costs only 199 US$,
so you save double !
It works by reestablishing the power factor back to 1
when inductive loads
reduce your power factor to less than 1 on the AC system.
Just click the banner to get one.
Many thanks.
Regards, Stefan.
allcanadian
@All
I find this thread simply amazing, LOL, here we have four pages of posts and nobody is wiling to state "what" power factor correction is nor "what" it does. We also have the critics who continually state their opinions as fact about things they obviously do not understand. Power Factor (PF) correction is not stealing nor tricking anyone nor anything it is simply a means to correct a power phase imbalance. Maybe we should start at the beginning--- and not the end of this process:).
A power company has AC (alternating current)generators and these generators move an electric current back and forth (a push then pull) in the conductors -- the current alternates! In a power plant we are continually correcting the voltage and current to match the customer load, we are also correcting the phase or power factor as different types of loads come on line -- Inductive, resistive and capacitive loads.
We can use a simple analogy here, if we have a mass bouncing up and down on a spring then the mass having inertia is like an inductance, the spring is resilient like capacitance and the air resistance is like electrical resistance. Now imagine this mass on a spring is bouncing up and down at 60Hz(cycles per second), if the spring and mass values are correct then a small external force (the generator) on the spring will keep the mass bouncing at 60Hz which is its natural frequency of oscillation. In this instance the generating force only needs to overcome the air resistance of the moving mass, if there is more air resistance then the generating force must increase to keep the mass oscillating at 60Hz. Now what if we added more mass (inductance)to the same spring value? Well the natural frequency of the system would be lowered and we would have to push and pull the spring harder and faster to maintain a frequency of 60Hz. This is what inductance does in the power line, it acts like a mass having inertia which wants to keep moving in one direction so we must reverse the applied force earlier (frequency)and we must push and pull harder because we are working against the inertia or inductance of the load -- not with it. Now instead of doing all this "extra" work to maintain our frequency of 60Hz why don't we just change the "stiffness" of the spring(capacitance) to compensate for the change in mass (inductance) in our system? If more mass is added why not just make the spring stiffer so the natural frequency is maintained at 60Hz without extra work? This is what the "magical" process of power factor correction is all about, they switch a capacitor into the circuit at the right times to compensate for changes in inductance exactly like we would change our spring stiffness to compensate for changes in mass. Now does this sound like something is being stolen? -- does it sound like we are trying to trick someone? No, this is just common sense and we are simply providing a means to increase efficiency. You see when we add an inductive load the system is now out of balance and by adding capacitance at the correct time we are simply restoring balance, it is no more complicated than that. Let's go back to our spring and mass for a second, did you notice that if we have to apply a force harder and faster to correct the system then we have done more measurable work at the source but this work does not show up at the mass load? Where or where has our work gone? It has gone into our spring of course which is moving faster and farther than it needs to generating losses due to friction, we could consider all this extra motion not required in a balanced system as heat losses.
Power Factor correction simply limits current flow due to induction with a capacitor which stores the energy as electrical energy in the capacitor. When the current reverses or alternates this energy in the capacitor now acts in series with the source to increase voltage thus current, it corrects the "time" at which current and voltage reach peak values limiting current flow so your electric meter runs slower --- because you are drawing "less current" not because you are stealing something.
AC
Goat
Hi AC
I've been looking at these devices for a long time as I used to work in a factory where the electrician had installed one to correct the PF used on the motors...he had explained to me how it worked and everything but it's been over 30 years so I forgot a lot of the info...so thanks for the info you just posted....
However...there seems to be a lot of articles stating that these are a scam because home power is not billed the same as factories or businesses which use huge amounts of electricity....here's a link to one such article I was reading earlier...
http://gadgets.boingboing.net/2009/02/22/power-factor-correct.html
and
http://powerelectronics.com/power_management/motor_power_management/power-factor-correction-0507/
I wonder if you could take a look at the replies at the bottom of these articles, I'd be curious to see what you make of it all...it seems like the power companies don't charge consumers the same way so it seems like a waste of money according to some...here's one comment....
"Utilities bill on KWH which is real power used multiplied by time. Power factor correction can reduce amperage if you have a power factor less than 1, but it will not reduce the real power or the KWH, which is what you are billed for."
Anyways, just wondering if it's all on the level...
Thanks,
Paul
allcanadian
@Goat
QuoteI wonder if you could take a look at the replies at the bottom of these articles, I'd be curious to see what you make of it all...it seems like the power companies don't charge consumers the same way so it seems like a waste of money according to some...here's one comment....
That article and the comments were interesting but have you ever got the feeling most everyone is just repeating what they have read from a textbook as all the answers sound the same? The problem is that many times people substitute real understanding of a process with memorized terms and equations, that is they can repeat what they have read but they have not taken the time to really understand what is happening nor prove the matter for themselves. I would agree with the comment above however reactive power does produce heat losses in the load which is real power we are billed for. Therefore power factor correction which reduces the reactive power in circulation does matter as it effects efficiency. I am sure we can all understand how much real power is consumed by even a small heating element, so why turn all our conductors and inductors into space heaters?
AC
forest
Allcanadian,
please help, I'm starting to understand what we need to know and what is important. Real understanding from the beginning to the end of current flow and magnetic flux flow.
Can you describe how LC oscillator is working , where is electric current flow ,where magnetic and IN WHICH PART of oscillation cycle ? I mean , there is for example starting 1/4 of the resonant wave - where is the electric energy now,where is current, where is magnetic field flux .
I realize clearly that LC electric circuit is like a pendulum so it has to contain kinetic and potential energy.I HAVE TO understand it !
