Cavitation: Is it the key to alternative energy?
Started by Grumpy, December 31, 2008, 08:49:22 PM
PaulLowrance
Quote from: Grumpy on January 08, 2009, 11:52:15 AM
Didn't Buzz test his theory with his latest build of Thane's E-coil?  Yep, that was a test and he explained the results with "cavitation".   Someone asked about adding a cap across the HV coil and Thane said he may have tried that and it may have decellerated the disc.  Why would it decellerate?
No, TheBuzz did not test his theory. Any nuclear fusion reactions will produce gamma radiation.
As far as explaining results based on an untested theory, anyone can come up numerous ways to explain something, but that is almost pointless until you test your theory.
PL
Grumpy
Quote from: PaulLowrance on January 08, 2009, 11:54:15 AM
PL
Can you point us all to a detector that can discriminate between true gamma radiation and any other induced charge effect?
Also, transmutation is not fusion.
        -Frank Edwards
PaulLowrance
Nuclear transmutation is the conversion of one chemical element or isotope into another, which occurs through nuclear reactions. It can be fusion or fission. Nuclear transmutation produces gamma radiation.
I've provided the links to a $15 Geiger counter in the previous cavitation thread that the Admin of this forum closed, and rightfully so. A Geiger counter uses a Geiger-Müller tube -->
http://en.wikipedia.org/wiki/Geiger-Müller_tube
PL
Grumpy
Quote from: PaulLowrance on January 08, 2009, 12:13:25 PM
PL
As long as you keep ignoring the fact that a Geiger tube is "indiscriminant" - I have nothing more to say about it and you can stop bringing it up.
If you had followed up on the work of Walter Russell, you would know that the transmutation I refer to in not the brute force nuclear reaction of conventional science.
Then there is this reference:
QuoteThe employees of RNC "Kurchatov Institute" Urutskoev, Liksonov and Tsynoev [23] organized experiments on the study of electrical discharge explosions of titanium wire in sealed polyethylene balloons, filled by water.
As a result this experiment, new chemical elements were revealed, which had not been present at the installation.
Amongst these elements produced were Na, Ca, Fe, Ni, Au, Pb.
Electrical discharge explosion of a wire is a form of "cavitation".  ;D
        -Frank Edwards
ramset
Paul
When the administrator locks a thread ,he always leaves a post with the reason[not so in this case]
As you know anyone that starts a thread can lock it
Chet
Thanks Grandma
