Problems with TPU building and Free energy devices in general.
Started by ben8807, January 08, 2009, 10:58:48 PM
nkovchak
otto,
can you help us to clear  undestood the physic's inside the device?....
we unable to build a device, what generate "something" from the space without mind!.
nk
rensseak
Quote from: otto on February 06, 2009, 01:42:09 AM
Hello all TPU builders,
Again, YOU HAVE NO CHANCE TO BUILD A TPU WITHOUT TUBES!!!!
properties of tubes and something totally different is to work with tubes, to connect them to coils.
Again and again: DONT USE MOSFETs!!!
I hope I was clear. If not then read my post again and again until you understand it.
Otto
Hi otto,
can you please tell us witch tubes you are using? The one SM mentioned (5U4-GB and so on) has a vacuum (in german Hochvakuum), so i think we have to look/care for it!
Thanks
Norbert
otto
Hello all,
@Norbert
Im using a 12AU7 double triode or in Europe it is a ECC 82 tube. The 5U4 is a rectifier tube. As a rectifier Im using 4 diodes 1N4007, I hope,ha,ha. I would love to have a rectifier tube ...hmmm.....maybe I have one???
I have a few various tubes. I have to see what types of tubes.
My tube is not the best triode but OK, I have to use it.
Again to TPU builders: DONT USE MOSFETS!!!
Otto
Mannix
Quote from: otto on February 06, 2009, 04:58:23 AM
Hello all,
@Norbert
Otto
Good one Otto!
ALL ,
They are easier, especially to begin with.
VHF tubes were mentioned like in the tuners of tv sets
Moray said that some worked better that others and did not know why
go hunt down some junk and try  ... what have you got to lose?
BEP
@Otto
Good going!
The ECC82 is a good start for most. My belief for important factors of the 5U4GB example was the heater is also the cathode. There was no separate cathode to prevent the heater signal from combining with the plate current. It is also known for lower internal resistance and higher current capacity.
The ECC82 may have speed issues because of size and lead capacitance but it is a good one to start . Who knows? Maybe it is all that is required.
Good Luck!
BEP
