Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
Groundloop
Hi,
I mounted a couple of NEOs onto a small electric motor and put the motor inside the coil.
The circuit coil was able to run the motor at relative high speed but I did not get any
voltage out of the motor. The next test was to apply a voltage to the motor from the
same battery as the coil circuit was connected to. The rpm of the motor did go higher
than just from the battery due to the fact that the coils also did spin the rotor magnets.
I did notice a couple of tuning point on the 10K variable resistor where the current
usage was lower. All in all the circuit did use way too much current from the battery.
I think this test shows that it is possible to make a NEO rotor that drives a generator
inside the coil. Maybe a small Muller generator is the way to go here?
Groundloop.
plengo
I have been testing my "sucessfull" setup with a small 12v wet cell lead acid 20 amp/h not conditioned to radiant energy and my results are miserable.
It only looses energy unlike when I used a conditioned battery. I can with certainty tell you that a conditioned battery makes a difference from night to day.
I am not even able to maintain the voltage as I did previously.
My next step will be to condition this battery with about 20 charge and discharges using my Bedini SSG and try the whole test again.
Fausto.
plengo
I am on the 5 charge cycle of creating a "reconditioned" battery for the continuation of this experiment. It takes lots of time.
Fausto.
Pirate88179
@ Plengo:
Now that I have my Bedini replication up and running, when I get time I will take apart one of my  48 volts fans and try to replicate this.  On my Bedini, (using two 12 volt motorcycle batteries) it ran what seemed like forever on the run battery, which, as suggested by Gadgetmall, I did not charge when I bought them, I just put it to work after the electrolyte was added.  I ran it until the run battery got down to 11.4 volts and my charge battery was up to 13.8.  I just switched the batteries last night and am running it again.
Best of luck to you on this replication and on your experiments.  I look forward to hearing of your results.
plengo
I am on cycle 8 of charging and discharging my battery (making it conditioned).
Oh boy, takes forever to do that!
Fausto.
