Fusionchip's Bedini Feedback to Source!!!
Started by Goat, January 09, 2009, 11:54:12 AM
triffid
Looks like to me old tvs and stereos plus old computers would be a good source of parts to build these bedini fan motor/generators.triffid
shabamsev
hey guys, I'm in the proses of gathering the things up i need to try this out, but i ran across a vary interesting fan and need some input. This fan is 12vdc it looks like 2  Bifialar coils windings, i have never ran across fan like this, could this be something to test with or is it just not going to work at all? any input would be grate. Thanks, Russ
mscoffman
@shabamsev,
Does this motor have permanent magnets in the fan
rotor? If it does then I guess it could be a two coil
DC motor rather then the usual four.  It would use
the armature iron metal to couple the magfield into
the correct spots. One coil could be used as the Bedini
sense coil and the other used for the drive coil. You
may need to add another wire connection if the one
common connection is not in the correct place for
the Bedini circuit.
If there are no permanent magnets in the rotor it could
be AC motor drive synthesised by the IC. In which case
it would not be a feasible bedini conversion.
:S:MarkSCoffman
