Thanks to ALL for your help!!
An other buoyancy based idea
Started by Gravitator, January 11, 2009, 05:43:06 AM
brian334
Gravitator,
Another problem is the heavy liquid is more dense than the light liquid.
The heaver the liquid is the harder it is to move it out of the way as the balls go thru it.
Or to put it differently the drag on the balls as they move thru the heaver liquid will offset the gain you get from the increased buoyancy.
Gravitator
Suppose the liquids are mercury and water and the balls are filled with mercury.
@brian
With this difference in dense I think the liquids will not be mixed. Or to be more detailed they
will mixed but they will get back to separate states quit quickly.
And if the balls are filled with mercury they are more or less like floating in heavy liquid.
Like balloon filled with water in bath. What it comes to drag on balls when moving in liquid I
think this can be decreased using different shape than ball. Something more streamlined.
@hans, @abhammer
In the version Hans show us the balls must have been filled with something lighter than water.
It could be air ? Or at least the dense of balls must be less than water. Without this they
will not rise up in water.
When the balls are so light it is difficult the get them through heavy liquid. That's why
I think the balls must be filled with mercury or other heavy liquid and not with air or other
lighter liquid than water.
@all
In the version Hans show us the movement is retrieved from buoyancy of light balls in water.
The idea in my model is to get the movement from balls falling down. The balls are bind to each other
like necklace of pearls. The falling balls will drag rest of balls which are "lighter" on left side
because of buoyancy. They are not lighter than light liquid.
In other words. Imagine that the balls are hang down freely without liquids. In this state they
will not move. The liquids are there to break this balance. I don't know if it is correct to say
that balls are dragging on right side or should I say buoyancy is pushing on left side?
hansvonlieven
@ Gravitator.
Can you not see that if the balls are heavier than the mercury they will not rise?
It really does not matter if your balls are sinking, they HAVE TO rise on the other side.
Hans von Lieven
Gravitator
@hans
They will rise. The idea is in breaking the balance using buoyancy like in attached picture.
The buoyancy is equal to amount of liquid weight the ball replaces when it is in liquid.
hansvonlieven
LOL
I suggest you study some hydraulics, Communicating tubes would be a good place to start.
Hans von Lieven
