Magnetic "Free Energy" designs released - finally!
Started by PaulLowrance, January 17, 2009, 02:06:01 PM
Tempest
Since no one has even offered a device to test this, would some thing like this work?
My thinking is to put two coils on each of the cores to make it easier to collect output energy.
Sorry i had to modify. I should have labeled the spring return soleniod
PaulLowrance
Thanks for making the drawings Tempest. That matches the description. One remaining area that needs addressing, besides magnetic viscosity pretesting, is how to properly absorb the momentum of the moving center piece as it suddenly stops. In terms of verifying that the high magnetic viscosity pieces cool down per entire cycle, one concern is to not heat up that area from whatever might absorb the momentum.
Perhaps a short, but stiff spring that's near the solenoid? Just as long as it's away from the magnetic materials because the spring would heat up.
PL
PaulLowrance
Sorry, I thought the following animation was already uploaded
http://greenselfreliantenergy.com/forum/index.php?topic=164.msg578#msg578
That is a recent improved version for design #1. It does away with the need for low magnetic viscosity material. More importantly, it does away with the need for the low viscosity materials special coil timing.
PL
Craigy
Solunoid is good , how about a mechanical linkage, like a ic engine when the piston reaches tdc, the time at tdc is considerably longer ...or a linkage like this
http://www.brockeng.com/mechanism/Whitworth.htm
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
PaulLowrance
It will be interesting to know how Steorn is pulling it off. IMO they found a type of magnetic material that has incredibly high magnetic viscosity. Perhaps I'll try an experiment in a few weeks, maybe, just to see how much viscosity carbon steel has.
Anyhow, here's a proposed priority list if I were to work on this-->
Priority #1 - Do some magnetic viscosity tests on various types of materials at various levels of magnetization.
Priority #2 - Build a simple machine using the material with highest magnetic viscosity for the sole purpose of trying to get the magnetic core temperature to drop per cycle.
Priority #3 - Build a machine for the purpose of self-running.
PL
