Youtube video of gravity device principle.. ?
Started by hartiberlin, January 21, 2009, 08:54:10 PM
GavinPalmer1984
Quote from: spinner on February 05, 2009, 06:31:32 AM
>>The partitioning scheme (which enables a proportionally the lowest energy input to actually completely  drain and then fully refill a certain amount of water(mass close loop displacement)).
Exactly... and the partitioning scheme is not fully developed.
>> In this thought experiment, we're not considering any losses
Yes and No.  Consider them so that the design avoids as much loss as possible. ( I am posting to get help from the online community... there are many brilliant minds out there)
>>and (as Gavin said) the energy (mass in a gravity field) mechanical equivalents are not the prime concern of this project...
The mass of the output unit is the source to lift the partitions.  The emptying and refilling (half-way) of the output unit's container is the source to reset the output unit.
So, I'd like you to continue with your explanations....
Several posts ago, I asked you about the whole picture (not just the part. scheme).
How is yours output unit supposed to operate?
The whole design is a work in progress.  I bring to the table many ideas which are possible.  I like to start broad so that others may work out other designs based upon my original concepts.
I think that the best output unit will be one in which the mass pushes air out of its container, which is used in conjunction with the partitioning scheme (with the partitions inside of another container), and air goes into the bottom of the partitioning container.  The air will then be used to provide buoyant force upon the bottom partitions.
I will not go into the "newer" partitioning model just yet... let me get a new video up with the 2.0 idea which will not only decrease the distance which M(water) will travel, but will also decrease the amount of work which the mass(output unit) must contribute to lifting all of the partitions(because only 2-3 of the bottom partitions will require a buoyant force... all other partitions will have received buoyant force from a lower partition).
I am taking baby steps... it is the best way in my opinion.
wattsup
@GavinPalmer1984
This forum has always been a very good place to test your ideas and I am the last one to knock anyone down if the idea holds up or not. As long as we can all learn more. Better having it analyzed here then shooting it out in the real world because the remarks and objections will not be as quaint. Actually they can be pretty rough here too. lol
Now that you appreciate the "real" task at hand if there is something else that we are not aware of, then I am sure guys here will be as helpful as they can. Please think it over very carefully and don't assume anything because nature will not assume anything and will only react in the way it can, not in the way one wishes. (Don't I know it.)
All the best in your further endeavors.
GavinPalmer1984
Quote from: wattsup on February 04, 2009, 10:28:29 PM
@GavinPalmer1984
Try this little quiz I made.
Put the following in order of least to most energy required.
1) Lifting 1000kg - 1 meter high - in one second
2) Lifting 1000kg - 1 meter high - in three seconds
3) Lifting 1000kg - 1/2 meter high - in one second
4) Lifting 1000kg - 1/2 meter high - in one half second
Hope this will get the point across.
Energy required for the partition to get up to max velocity:
W1 = (m * d1 * g) + (1/2 * m * v^2)
Energy required for the partition to move with acceleration = 0, aka constant velocity:
W2 = (m * d2 * g)
Energy required for the partition to slow down to v = 0 and reach destination:
W3 = 0
So the overall work will be:
W = (m * d * g) + (1/2 * m * v^2)
d1 + d2 = d ~= 2 * H/n
So:
Work(1) = 1000kg * 1m * 10 + 1/2 * 1000kg * 1
Work(1) = 10000J + 500J = 10500J
Work(2) = 10000J + 56J   = 10056J
Work(3) = 5000J + 125J   =   5125J
Work(4) = 5000J + 500J   =   5500J
Realistic dimensions would mean that the height (y-dimension) of the output unit's holding container would be roughly equal to the depth(z-dimension).  The width(x-dimension) would be larger than the output unit's width.  The height and depth would be roughly twice the height of the output unit.  So each partition would have a width and depth which is equal to the output unit's container's width and depth.
Let's use these dimensions:
Output Unit:
(y-coordinate)height = 22 meters
(x-coordinate)width = 3.7 meters
(z-coordinate)depth = 3.7 meters
Let us assume that the mass of the output unit itself is zero and only the falling mass (piston) is accounted for.  We will also ignore resistive forces for now.  There are efficient geometric shapes which should be used... I may not be using the most efficient shapes.
mass of piston < Volume of output unit  * density of water
m(p) < V(ou) * p(h2o)
this is where you would account for a temperature window so that the output unit is always buoyant no matter the temperature... temperature affects density.
m(p) < 22 * 3.7^2 * 980kg/m^3
m(p) < 295,156.4 kg
The mass will be able to fall roughly 1/2 of the output unit's height.
Output Work = m * d * g
OW = 295,156.4 * 10 * 9.81
OW = 28954842.84 J - (f1 * 10)
f1 = friction on inner walls over 10 meters
Output Unit's Container:
height = 45 meters
width = 4 meters
depth = 45 meters
mass of water exchanged = m(h2o)
remember, water exchanged must be greater than the height of the output unit.
m(h2o) = Volume of h2o * density of h2o
m(h2o) = 4 * 45 * 22 * 980
m(h2o) = 3,880,800
Partition:
width = 4 meters
depth = 45 meters
ignore inner-operations for now (there is potential energy which can be harvested from other sources within the process)
Input Work = work needed to exchange the m(h2o) = IW
IW = (m * d * g) + (1/2 * m * v^2) + (f2 * d)
d = 2 * 22/n
n = number of partitions
m = m(h2o) = 3,880,800kg
f2 = friction encountered while lifting
We need:
OW > IW
OW = 28,954,842.84 J - (f1 * 10)
28,954,842.84 - (f1 * 10) > (3,880,800 * 2 * 22/n * 9.81) + (1/2 * 3,880,800 * v^2) + (f2 * 2 * 22/n)
Ignoring friction:
28,954,842.84 > (3,880,800 * 2 * 22/n * 9.81) + (1/2 * 3,880,800 * v^2)
n = 100;
v = 0.22 m/s;
height of a partition = 0.22 meters;
28,954,842.84 > (16751085.12) + (93915.36)
28,954,842.84 > 16,845,000.48
Excess work =  12,109,842.36 J
with friction:
28,954,842.84 - (f1 * 10) - staticfriction1 > (3,880,800 * 2 * 22/n * 9.81) + (1/2 * 3,880,800 * v^2) + (f2 * 2 * 22/n) + staticfriction2
28,954,842.84 - (f1 * 10) - staticfriction1 > (1675108512 / n) + (1,940,400 * v^2) + (f2 * 44/n) + staticfriction2
n = 100;
v = 0.22 m/s;
28,954,842.84 - (f1 * 10 meters) - staticfriction1 > (16751085.12) + (93,915.36) + (f2 * 0.44 meters) + staticfriction2
28,954,842.84 > 16,845,000.48 + (f2 * 0.44) + (f1 * 10) + staticfriction1 + staticfriction2
Relatively bad coefficients of kinetic and static friction are 1.0 and higher.
Force of friction = Normal force * coefficient of static friction + normal force * coefficient of kinetic friction.
Unrealistic worst-case friction:
normal force is related to the area of contact between materials and the pressure exerted.
width of seal = 0.05m
the piston is cube shaped = 4 sides that are 1m long
use 2 seals
normal pressure might be 75,000 N/m^2
for staticfriction = kinetic friction (I am using bad coefficients so this is safe)
f1 = Area * Pressure * coefficient of friction= (0.05m * 1m * 4 * 2) * (75,000) * 1.0 = 30,000 N = staticfriction1
28,954,842.84 > 16,845,000.48 + (f2 * 0.44) + (f1 * 10) + f1 + staticfriction2
28,954,842.84 > 16,845,000.48 + (30,000 * 10) + 30,000 + (f2 * 0.44) + staticfriction2
28,954,842.84 > 17,175,000.48 + (f2 * 0.44) + staticfriction2
28,954,842.84 - 17,175,000.48 > f2 * 0.44 + staticfriction2
11,779,842.36 > f2 * 0.44 + staticfriction2
if f2 + staticfriction2 / 0.44 < 26,772,369, then this device can definitely be perpetual.
check this out:
OW = m1 * d1 * g - f1 * d1
IW = m2 * d2 * g + f2 * d2
Doubling the dimension:
OW = 2*(m1 * d1 * g - f1 * d1)
IW = 2*(m2 * d2 * g + f2 * d2)
All of the masses double.
d1 will double.
d2 can stay the same... aka double the partitions.
If you ignore friction, doubling dimensions and partitions will quadruple OW but only double the IW.
The work done by friction for OW will quadruple because of the increased distance for f1 and the area of contact for f1.
I will not make the claim that the work done by friction for the OW will increase with doubling the dimensions... that just limits the innovation of the design.
Also, I know that there are better geometric shapes which should be used... I happened to use bad ones, and still brought forth great evidence that perpetual motion is possible.
I should add that any other losses within the system are a direct result of the design and implementation to achieve the desired (basic) operation.  For example, creating electricity from kinetic energy has inherent losses.  And storing / transferring that electricity has large inefficiencies.  The designers should conclude, that the use of electricity to maintain a desired state of the device should be avoided... Unless the electrical conversion/storage/transfer processes are increased to an efficiency which is at least equivalent to the inherent resistant forces (friction) within a system which avoids the use of electricity (compare direct mechanical work through pulleys and levers to that of an electric motor) for the same purpose.
mondrasek
Gavin,
I believe there is a problem with how you think the output device will work.  Once it has been lowered below the catches and the water level returned to full height, the output unit will not flip.  Even though it is buoyant and will want to rise, the majority of the weight will be at the bottom.  Much like the ballast in a boat, having the CG of the output unit at the bottom will keep the unit from being able to flip back to the surface.  It will want to rise, but only straight up, not flip.  You will not be able to reset the weight in the output unit using this system as shown so far.
Thanks,
M.
GavinPalmer1984
Quote from: mondrasek on February 07, 2009, 05:25:37 PM
Gavin,
Thanks,
M.
I think you are right.  The mass will need to be smaller and will be determined by the amount of displaced water which is lower than and/or level with the mass.
But the point still stands (although a hole has been shot in the master-plan):
output unit is constant.
reset work is variable.
I appreciate the help... maybe there is a better output unit design... the previous detailed example will not work because the mass in the output unit is too large.
