Finally I think I got it !
Started by Gravitator, January 27, 2009, 12:26:13 PM
AB Hammer
Gravitator
Did you get the design I sent you?
Alan
AB Hammer
Gravitator I have waited on a reply long enough.
Greetings All
I am publishing this Design under copyright. Feel free to use the information to build any device you wish. When it comes to commercial exploitation I reserve whatever rights are given to my by law.
Alan
AB Hammer
Greetings All
I not going to say this will work. But from the direction of this string I see this as a possibility if at all. It rocks back and forth giving time to fill by natural vacuum the upper bellows bladder and the holding pool is to insure that it stays in position until the upper bellows bladder if full enough to rock back and repeat and pouring out the water tray that goes over the water wheel/turbine to produce some energy. The trays do not hold all the water from the bellows bladders and will be pouring out to the water wheel/turbine. This makes the trays a timing device to keep the action going. I hope you like it, from the designs I am working with this one was low on my agenda.
Alan
hansvonlieven
How are you going to restore the vacuum in the bladder once it empties itself Alan?
Hans
AB Hammer
Greetings Hans
The weights connected together on a sliding rail. This way as the weight slides down once forcing out the water on the low end up to the holding pan as it rocks the weight itself starts forcing the upper bellows bladder to open causing it to suck up the water into it, not unlike sucking a drink up a straw. My estimate if it can work, would be very slow operations. But LOL it might be an improvement over the drinking bird, for it would really drink.
Alan
