Finally I think I got it !
Started by Gravitator, January 27, 2009, 12:26:13 PM
rlortie
The Posting is February 17th   On Free-Energy@yahoo.com
QuoteNew Development on perpetual motion
Posted by: "jackstraw6432" jackstraw6432@yahoo.com   jackstraw6432
Tue Feb 17, 2009 5:27 pm (PST)
Hi
Discovered the following address and I think it might be worth to look
at ...
http://freepowertofreepeople.blogspot.com/
el-tigre
Gentlemen,  A suggestion that may help with your pump construction.  Valve 2 & 3 are simple float flapper valves. (Look in your toilet tank for a common cheap example)  Rotate valve 2 by 90deg and relocate to the bottom of the tank to align with valve 3 and they can be activated automatically by a simple verticle rod affixed to poke open valve 3 when it falls and a string to pull open valve 2 when the float rises to the top.  Valve 1 looks like a common foot valve to me, it will automatically open and close as the fluid is drawn into the tank, no external control necessary.
P.s. to all the naysayers, do not be too hasty dismissing the experimental researchers, it is entirely possible to convert potential energy through kinetic energy and into usable work with nothing more than gravity, harmonic resonance and 2 valves. Here is how I did it, explained in detail for anyone to build and use themselves...
http://www.instructables.com/id/Worlds_greenest_water_pump
Fluid systems can be made to behave in unexpected ways. Keep on experimenting.
