Panacea-BOCAF 2nd MRA replication -COP =8
Started by ashtweth_nihilisti, January 27, 2009, 08:16:43 PM
ashtweth_nihilisti
Stefan we are fully aware of what we need to do next. This is a progression of research and measurements.
As for yourself, i suggest you get the same LEDS and SAME signal generator, you will only light up 6 LEDS
The 20 we lit up were bright enough, i know from being there. I will not be answering these posts again.
I suggest you follow the PDF.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
hartiberlin
Hi Ash,
many thanks.
I have now read the PDF file from:
http://www.panaceauniversity.org/Magnetic%20Resonant%20Amplifier.pdf
So you have used pretty old LEDs, right ?
Okay, that might then fit with the output LED power ratings.
Would be nice to see some scopeshots in a new video.
Does it really need this BariumTitanate speaker or
is a Silver cap or a piezo from
a piezo horn speaker also good to do the job  ?
Would be nice, if you could scale up the power
level and do it all with DC voltage measurements at the input and at the output.
Many thanks in advance.
Keep up the good work.
Regards, Stefan.
ashtweth_nihilisti
Hi Stefan,
if you read the PDF you can see the exact part number and LED we used, they are not old ones.I cannot comment on other piezos as we have only tested the ones provided to us by Norm and Joel.
We are not able to find off the shelf parts at this time sadly, this is why we need more staff and volunteers to help. As we stated on the video, we intend on a re wind and the analog DC in and out.
Ash
poynt99
From the document, Norm said he was trying to make a DC powered generator with CMOS gates. This would have been a square wave oscillator, so I suspect this should work also. I wonder if he had any success with this oscillator, and if not  why?
This would be a straight-forward circuit to design, especially if only 80mW was required from it to drive the MRA.
.99
ashtweth_nihilisti
Hi poynt99
Norm has not been able to build one yet, i think the CMOS gate driver was a suggestion we got for another forum. Thing is you have to make it so the duty cycle does not change when you adjust the frequency. Perhaps you could design  these circuits and post? don't worry if those thing are expensive, I think we did get it working on a square wave, will confirm in a few hours.
Ash
