How the Gray Tube Circuit Works
Started by qiman, January 29, 2009, 03:45:58 AM
qiman
qiman
It is definitely not about discharging a HV cap into the tube to get the tube to spit out something special. The tube passes the HV from power source to the cap on the back side of the inductor....then when switch at LV rod is closed, that cap collides with front side HV cap and moves to common ground.
Anyway, this is obviously my opinion but based on experiments...see my vid.
The magnet didn't push away because I had the polarity backwards...coil was tugging magnet to it but you can hear it yanking on the entire bicycle wheel and stand. More later...
pese
Quote from: qiman on January 29, 2009, 03:45:58 AM
Watch this video:
http://www.youtube.com/watch?v=8y0921zaPxQ Gray Tube - How it works.
try to use an simply car breaker contacts.
driven mechanical by an electromotor.
use also an car ignition coil.
this will save you (and other) to drive the
transistors (that are also the wrong typ to
do this job !! .Think to use High voltage Diodes
- some fast switching (!) diodes in series to use this
for used KV).
Pese
AhuraMazda
Video works fine here. As for the green flash I know that crooks tube give a green glow due to the excitation of the glass or so they say.
