Newsflash: Overunity is impossible
Started by newsflash, January 30, 2009, 08:17:48 PM
Nabo00o
G-search Gary's magnetic motor.
Yes you cannot truly block a magnetic field, but you can absorb it, and remove its effect for a certain area. To do this you need to find the neutral line of a magnet, preferably a horseshoe magnet. Once you find the neutral line, you can move a piece of soft iron parallel to the line without doing any work, but you will hinder the field in moving farther away.
Gary did this with two horseshoe magnets years ago. Its very hard to find, and even harder to perfect, but when set up correctly you can practically turn on and of a magnetic field without doing any considerable work.
And the energy again...where does it come from!!?!?
Well, it comes from the virtual particle flux, which is the prime source of all energy existing in the physical world, and according to present particle theory, it "bounces" back and forth between a real state and a virtual state, which means that at one point it exists as a true particle, and in the next one it disappears completely.
'Real' over unity does not exist, just like 'real' under unity does not exists.
In every theoretically "closed system" which we can think of, the energy inside will always be in perfect unity. If not, then either something was created out of nothing, or else something was destroyed. You can do NEITHER to energy.
Free energy is what this forum is all about, most of the researchers here have probably arrived at the same conclusion.  You cannot create something out of nothing, it is as physically impossible as it is philosophically impossible. Guess what karma is? It is the results of your own actions acting towards you. You cannot live of on other peoples sweat and tears, and then hope that it will stay that way.
Every actions causes a reaction, of some kind.
Think about that....
Static energy...
Dynamic energy...
Two forms of the same.
friendryan
Ok, that didn't make sense. You can do "You can do NEITHER to energy", whe it comes to creating something out of nothing or else something was destroyed. Right before that you just said "it bounces back and forth between a real state and a virtual state, which means that at one point it exists as a true particle, and in the next one it disappears completely.
If it disappears completely then it's like it's destroyed and when it appears it like it's created from nothing. LOL. Energy created from nothing is very common from your first statement if it's disappears completely. If it's gone completely and does not exist and it comes back all of a sudden then you obviously can get energy from nothing. Come on now. Don't contradict yourselves because none of us really know what is really going on when it comes to tapping energy and at the same time trying to explain why the universe works. :)
nyctuber
Quote from: zydubion on May 03, 2009, 10:49:45 AM
Nyctuber...Since you did not read my post correctly, I will repeat and use other words so you understand....Present so called shields are have no affect what-so-ever on permanent magnets.  When I say SHIELD, I mean SHIELD as in totally block out the magnetic field. No material in the universe as of today has that ability.
http://www.youtube.com/watch?v=H6bE9TzetSA
Looks like a total block to me. His motor attempt didn't work.
Nabo00o
Quote from: friendryan on May 08, 2009, 09:22:39 AM
You misunderstood me, or I didn't explain the obvious.
Energy is not created and is not destroyed.
The fact that todays scientists thinks that particles are created out of nothing and then destroyed again, only proves that they doesn't have the full picture.
Probably, at the border where the physical particles of energy goes over into the "virtual", it has left the physical world, and enters another world our dimension which we today cannot comprehend.
The theory of Broken Symmetry which is highly recognized, assumes that energy is destroyed and created all the time, at incredible rates and magnitudes.
This is the Virtual Particle Flux, but we can only see one side of it.
Therefore we 'assume' that the energy disappear.
I hope you get now what I was trying to say.
Of course its not so easy to explain how the whole world works ;D
But then again, it is a thought problem which is meant to be solved ;)
Static energy...
Dynamic energy...
