HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
Outlawstc
so buzz
yea me englesh may not bee thee best but i dont care enough to perfect it. lol anyways so you say you have read it 10 times? where should i start for making a 350 chevy run on water? what are the components needed?. i need a alternator some ferrite rods and alot of wire? a good  diode for the positive choke? are the chokes wound together or seperate? what size wire should i use? what do i need to build to power it?? if im being misled can u  give me an overall of what i need to fix my misleaded mind? can you do that? maybe people might stop arguing if you give a overall and they see your full side of the story... ive only read his material twice and i havent sunk the value of a plane in my projects. so im not as far along. people need to stop fighting it weetoded..
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
Outlawstc
buzz your hilarious.. you sound like you must have been a mommas boy. just remember in real life not this internet chat fight that i am the ALPHA male your just a little prison june june. your talk to try to make me sound stupid only humors me..  i know if we met in person you wouldnt say one word that you have said on here to my face.. and thats what makes you a june june. i would bitchsmack you so quick you would run to ur mommy crying for the teet.
for reading the work 10 times and spending so much of your time and money on this you  dont understand the multi-spool coil? how could you have spent so much money when you just admited you dont even know the wiring for the choke multispool choke bifiliar wound bobbins??.  seems like that would be somthing you just fell into figuring out with lots of money in experimenting..  lol thats funny.  then you mention showing off your sine waves soon lol..kevin west can show you a good tidal wave on his youtube videos all day. yours will most likely be a computer animation of your imaginary setup working.
good luck on being a little june june in your gaily life.
ramset
Can you hear that?
Nothing!!??
SHHH.. I thought I heard something!!
Shudup and eat your popcorn!!
Its Friday the fights don't start for hours
Shh...did you hear that...It sounded like a shoe dropped??
Thanks Grandma
AhuraMazda
Chet
Dont make comments comments like that.
This thread was built on mutual disrespect!
Outlawstc
ladys and gents,
things to know about inductor chokes
1- The current that an inductor can handle depends on the size of the wire. The inductance
does not; it is a function of the number of turns in the coil, the diameter of the
coil, and the overall shape of the coil.
2- In general, inductance of a coil is directly proportional to the number of turns of
wire. Inductance is also directly proportional to the diameter of the coil. The length of
a coil, given a certain number of turns and a certain diameter, has an effect also: the
longer the coil, the less the inductance
3-Very small coils, with few turns of wire, produce small inductances, in which the
current changes quickly and the voltages are small. Huge coils with ferromagnetic
cores, and having many turns of wire, have large inductances, in which the current
changes slowly and the voltages are large
4- As long as the magnetic fields around inductors do not interact, inductances in series
add like resistances in series. The total value is the sum of the individual values. It’s important
to be sure that you are using the same size units for all the inductors when you
add their values.
-all in all we know that current is determined by size of wire used.
-inductance is determined by geometrical demensions of coil  and has direct relationship to number of winds.
-the longer geometrical coil the less inductance.. thats why 6-1 magnifies in individual cavities it is considered a 16th of an inch inductor. and its like having 14 seperate chokes in series. its also why the choke in his water polarization unit is small.
-Huge coils with ferromagnetic cores, having many turns of wire, have large inductances, in which the current changes slowly and the voltages are large
note of number 4- As long as the magnetic fields around inductors do not interact, inductances in series
add like resistances in series..
they are definatly interacting which would take away resistance in 6-1. this i beleave is why the all in one unit requires resistive wire.  then again depending on how the choke wire is wired you can have 2 seperate wires (Bifiliar) flowing the same way?
outlawstc
