HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
kinesisfilms
Quote from: ramset on February 04, 2009, 04:18:43 PM
kinesisfilms
You said you had this figured
You spoke of a release of your findings
If you could clear this up ?
Well..... there are no words for that
     Chet
yes i will clear everything up.....i have a spectrum analyzer a tektronix 496....i have a function generator for sweeping, i have an oscilloscope for lc resonance...i have everything BUT bnc to banana cables and banana cables to type n RF coaxial since my spectrum analyzer goes to from 1khz to 1.8ghz in measurements.......i have a low power working COPPER non resistive working version....we are talking approximately 100 volts from a 12 volt power supply.....i have a double pulse which was impossible to get prior.....but once i figured out the RLC "secrets" (it's only considered a secret since no one has ever looked into it and realized that too high of a frequency will cause your coil to act only as an inductor and to low of a frequency will cause it to act only as a capacitor...defeating the purpose of the bifilar wound inductor and therefore can never achieve the affects of a manual dc lc resonance).....thus you will have no second pulse.......ONCE I GET THE CABLES...i will have my stored energy pulsed exactly as the first is creating the double pulse...WHICH TO THIS DAY HAS NOT BEEN DONE AS DESCRIBED IN STANS PATENTS....everything i am witnessing i exactly as it looks in stans drawings....EXACTLY....now once i get my cables i will be able to provide FACTUAL information that is UNARGUABLE......then i consider this to be truely replicated....not some J Naudin type scenario or some hydrocarz mystery videos......i have an actual lab setup now......IM SORRY IT HAS TAKEN SO LONG BUT HONESTLY IT TAKES A WHILE TO ACCUMULATE 1,204 DOLLARS OF SPENDING MONEY........and after that i just step up everything to larger values which can only BE DONE WITH RESISTIVE WIRE......but simply winding resistive wire around an audio frequency pulsed core will not create HIGH VOLTAGES AT ALL.......dankie seems to think it is very easy......dankie you have honestly no idea.....the mathematical variables will in fact only go so far before there are too many unknowns to compute and that is why i have purchased a spectrum analyzer and a simple oscilloscope will only help you find the resonance between the vic and wfc but not the optimum frequency for your vic and core.
i am not a whack, i am not a hick in the woods, i am not a child, i am honestly doing this to end this once an for all and get this fucking information out there. BUT TIME TAKES MONEY AND THAT'S A BITCH.
so please understand i am one person.
ramset
kinesisfilms
Thankyou for your reply
There really are no words to describe your action   [that would do this justice]
      Chet
Thanks Grandma
Grumpy
Quote from: kinesisfilms on February 04, 2009, 05:15:14 PM
What second pulse?  Where does Meyer ever mention a second pulse?  Are you sure it is not a reflected pulse?
RLC or LC resonance?  then why does Meyer clearly state in WFC 425 that the VIC coil arrangement allows voltage across the chokes while current LAGS 90 degrees.  When at "resonance" current and voltage are in phase.
Stop making the VIC coil so damn complicated.
        -Frank Edwards
dankie
Quote from: Grumpy on February 04, 2009, 06:47:04 PM
The VIC is not complicated , we know what core was used , what bobbin material , what wire size , what wire , the desired resistance of the chokes , detailed sizes ... We have the pictures of it thx to Dynodon ... Its just a modified pulse transformer and everything makes 100% sense so far , everything is extremely coherent ... We have already identified nearly all the variables ...
We have Stan on video telling us this is it , we have the briefing telling us this is it ... We have pictures of it ... We have alot of info on the VIC now
http://youtube.com/watch?v=IjEXnsPbzSg
The only thing thats complicated is what you make of the VIC with your stories and speculations ... Just follow the evidence , its that simple , Meyers wasnt lying to us , you can see that the Gas processor and the VIC are identical to the drawings found in the tech brief .
Everything makes 100% sense , everything is 100% backed by evidence ...
Grumpy
Quote from: TheBuzz on February 04, 2009, 07:04:04 PM
Grumpy - The second pulse I think he is referring to is in Meyer's notes he shows one pulse in but get's two pulses out. Now the only way I know how to do that is with a pulse compression.
Read my last post to "K".  (VIC coil can rest in peace.)
Yes, you get two pulses, one positive and one negative - from one input pulse.   There-in lies a secret, by the way.
(It sounded like he meant two of the same polarity.)
Quote from: dankie on February 04, 2009, 07:04:56 PM
The only thing thats complicated is what you make of the VIC with your stories and speculations ... Just follow the evidence , its that simple ...
Dankie,
What Stan doesn't say about the VIC Coil is what matters, and he never mentions the most important.  No one has ever mentioned it.
Your wire would actually help to some degree.  It's not required by any means, but it would help.
EDIT:
Buzz, check yer mail too.  Last piece is there.   (Got Stan's ghost in the figure four and he's howlin'...LOL!)
        -Frank Edwards
