HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
stevie1001
Quote from: hartiberlin on March 02, 2009, 06:37:51 PM
TheBuzz and his other 2 usernames
Meltdown and CabinBoy are banned now.
He violated many of the forum´s TOS and he was warned already
in earlier times.
Also I deleted one of his messages,
where he revealed personal information of another user.
Regards, Stefan.(admin)
Very good Stefan.
br
Steve
ramset
Farah Day
If you can contribute useful information ?
you should
Chet
The proof is in the pudding
Not the talk [Theories]
Thanks Grandma
ramset
Spewing
After reading your posts on wasting  Hydroxy
Your point is well taken  .Only gas that gets in when the intake valve is open actually does work!!
We dont need hydroxy to purge out burnt exhaust or waste during the rest of the strokes[3]
With a flame front of 8500 Feet per second [it all gets burned [not like gasoline or PETROL]
So it sounds like comparing HHO   BTU  TO GASOLINE BTU [for power purpose] ,and injecting the equivalent HHO at the right instant [instead of free flow through a carburetor] is what you are getting at
Myself
I would like to take smaller steps.Your success with no electrolyte ,Is HUGE ,just how huge would be explained with a little more info
How many watts are you using in your last video with straight water?
I'm glad you are working on engines ,I would like to work on home heating. less moving parts faster results and some anomalies about HHO and different metals ,ceramics that should be open sourced
If you can share any of what you are doing to make that much gas with no poisonous additives,
That would be fantastic!!
This is the key to HHO and home heating ''pure water''[within reason] no electrolyte ,no chimney ,all heat does work!!
Chet
This is already being done in south Korea [a secret process ]
http://www.browngas.com/eng_bestkorea/history_1.htm
OPEN SOURCE!!
Thanks Grandma
Outlawstc
i would say this is one of the most important statement stan makes when it comes to gas production.in the wfc tech.
QuoteIn each and all "Space State" of changes,
the combustible gas atoms of water is/are "Electrically Stress" under "different" pressure levels to bring-on
the triggering point of thermally igniting the combustible gases of water beyond or away from "Stable State"
of Equilibrium. Voltage Tickling of State Space under "Resonant Electrical Stress" without amp influxing
while "Tuning-ln" to the dielectric properties of water is herein referred to in this WFC Tech-manual as
"Resonant Action."
"resonant electrical stress"... he means so much more by that then most people can see at the moment... its not just hiting the cell with equal volts it oscillates as well.. you will see stan speaks of static voltage and dynamic voltage.. those are two different types of application of the voltage and those two in combination with waterfuel cell he calls "resonant electrical stress" if it was just the voltage being applied wouldnt he call it somthing like resonant voltage stress? if i were to compare the way the cell is hit.. i would compare it to A/C but its not the same..if i were to name it my self i would name it S/C switching current.. see A/C is using the electrons in wire to alternate. S/C allows the potentials to remain on there sides.. like the positive will be switching on and off while only putting off a positve field.. the negative side will have the electrons.. oscillating like a/c.. when turned on and off..  ..image hitting it in this sequence in repetition...
+B/0v                   +B/-B                    0v/-B
dynamic                static                    dynamic
outlawstc
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
dankie
Quote from: Spewing on March 03, 2009, 09:29:55 PM
My choice was to Allow all guest to read the ionization website, after i seen clearly that private sites is not good. The Reason you have to become a member at ionizationx.com to view anything is because stevie has gotton over 200 + advertisers and bots registering on his forum, I guess Stevie does not like bots and advertisers on his forum would be my guess. So that's the reason its members only... At least that's what I've been told.
I do care about what people think about ionizationx.com because i created it, At the time of its creation i wouldn't allow allot of stans devices on that forum. The forum was created just for Stanly's alternator. Its Stevie's forum, he runs it the way he wants, he deletes or adds to it what he wants. Me and Stevie are like brothers, I have mentioned to him that i wanted the forum certain ways (because it effects my appearance), also told him that i wouldn't carry the name that the forum was starting to give me,,, Which was free energy devices. I do not like to be known personally for claiming a free energy device if you want the truth, and if ionizationx comes down to that I'll leave! That's what i mentioned to Stevie and he also agrees somewhat.
There is nothing wrong with searching for Overunity devices, its just not who "hydrocars" is, or what he does. I pretty much am trying to crack this and run an engine on very low amounts of hydrogen and explain the workings rather than refer to it as free energy, all though it could be free energy i doubt you'll here it coming from me.
So if you come into our site with an overunity attitude, you probably will not catch my attention.
I am only a member there that enforces the rules that i mostly make, which the only rules there is be civil, do not take over other members threads, and no scroll posting in someone Else's thread, I usually give warning a few times before i take action. If i give warning to that member I'll be watching them. I've adjusted dankies attitude and I've also banned him, I also ask him to fix his attitude and come back to my forum. He clearly See's my way of direction and i have gained much respect from him, i also respect dankie as you all can see.  I would have respected buzz and give him a chance, Sometimes when you are as far gone as buzz was your better off not to attempt it. Dankie has become a changed person weather you know it or not.
I didn't think that kid would ever gain respect, but he did. I put my faith in the fact i could clean him up, and thats what i did. Today he still remains an ionization member, and he is one of our most active members. In fact, i just sent him an instant message because i'm concerned why he hasn't been posting much. i'm thinking he could have been threatened. I warned him to stay away from buzz since he was selling wire, and i have reason to believe buzz is an lawyer, "since he appears to know if what we're doing is illegal or not."
The reason i did not take action on buzz back then,, He had me between a rock and a hard spot, this could be where dankie is. Well,, It's not so easy to put me there a second time since stevie took the rock.
When i started this thread i had a goal, Now its goal has been meet. Its not wasted space, and it should not be deleted.
Some amateur hacker is trying o hack my comps , I had to shut down my 2 comps wich had XP yesterday . Only my bro's comp , the vista comp caught the burglar , its a program that tries to access my comp but gets blocked by vista .
Its like , when I click on an icon like the home icon for example , a download starts without my consent and my mouse is frozen , this has happened to me on this site and on energeticforum.com ( when I was using a proxy for that site ) . Had to shut down my power supply in a panic .
This is * pissing me off , cant open my comps now .
