HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
ramset
Outlaw
BAD VIBE??[POSTING NOTHING BUT FACTS , MATH, AND SCIENCE, GIVES YOU A BAD VIBE???}
You give me one place I can go ,to learn how to make heat, with pure water[not gas chambers using electrolyte]
                                               OPEN SOURCE!!!
AND I WILL LEAVE THIS THREAD TO YOU AND YOUR  CORVETTE
Chet
PS Average home 125000 BTU Furnace
I KNOW IN THE SOUTH YOU CAN HEAT YOUR HOUSE WITH A CANDLE[so why should you care]
And the lastperson to freeze to death down there ,probably got stuck in his freezer
Thanks Grandma
Outlawstc
ramset,
once you learn the vic , you will be able to produce enough gas from a water fuel cell to use with a furnace... there is one variable.  how hot the gas will burn.. controlled by how much of the burnt (noncombustables) gases you allowing to mixing with incoming fuel gas.. thats all you need to learn how to do.. i understand its cold.. and im sorry that people are going threw hell. if thats the case where your at.. why not focus on the water fuel cell and creating the system to unite non combustables on a regulative level back to retard flame front.. you are talking about furnaces but then your talking about systems that are being developed for adjustments into higher heat potential outputs.. you do not need to ionize air for a furnace..
outlawstc
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
ramset
OUTLAW
Its very simple, Where I and a lot of people live ,a car may or may not be required, on a personal level
HEAT, a whole different story, LIFE AND DEATH STUFF
A furnace that runs on water and makes 100000 BTU at very low wattage to heat ratio
                                                   NO SUCH THING
                                               Lets change that shall we?
   Chet       More to come gotta get back to the bench
OH and by the way did I say? where theres heat there is AIR CONDITIONING!!
Thanks Grandma
Outlawstc
heres a visual for alternator pulsing for vic burst sync pulse 8-11 wfc tech
ramset
outlaw
Thanks bud
I will look more at that when I finish on the bench
Chet
Thanks Grandma
