HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
ramset
Gentlemen
You are changing the world
I know the sting, It does not feel good [to say the least]
But the 99.9999..... % of the people in the world that will benefit from your hard  work
Should not be lumped in with the,,,,,,oooo1 % of  Shitheads that claim your  hard work as their own
THANK YOU FOR ALL YOU HAVE SHARED!!
The world needs more men like you
and much less of the other
   Chet
Thanks Grandma
TheNOP
Quote from: Spewing on February 02, 2009, 12:36:21 AM
AHHHH,,,,, This is the post i was aiming for!
Guess i don't need to be hanging around here on these forums Showing you how its done since you seem to have it all figured out....
It took long enough, But i made the point i Intended to make when i started this thread.
Who else knows how to do this? Step on up here
are you sure you wanted to show something and not just brag about what you know ?
why hide your source ballast in your videos if you want to help everyone here ?
oh!, yes, i almost forgot, so no one steal your hard work...  :(
Grumpy
Leakage transformers are used for arc welding and high voltage discharge lamps. It acts then both as a voltage transformer and as a magnetic ballast.
Some ignition transformers, such as those for oil burners, are also current-limited.
Whoop-de-doo.  There are several ways to limit current.
        -Frank Edwards
Spewing
Wow, i never knew there was so many ways to restrict amps ("and allow voltage to take over during a dead short condition in the tens of thousands range all while hitting resonance")...
Fore example, if you add 100 volts to a tube cell and it draws 10 amps, you restricted nothing because its a dead short of 10 amps. If you apply tens of thousands of volts to this same tube containing the same water, and your current flow is in the milliamp range and the voltage reading is in the thousands, Thats not scientificly possible. its called a "Working" vic. Restricting amps in a dead short condition while allowing voltage to take over and PERFORM WORK.
I been working on it 2 years,,,, and i've only found how to do it. "When dealing with myers vic that is."
If you know how its done, Why did you not tell me this 2 years ago? There really isn't any need for me to share anything with anyone since you guy's are saying its an easy process.  I guess i was the slow one, "It took me the longest to figure it out."
Wait until you see my 3" OD vic. The vic now makes a good wat not.
Restricting amps and allowing voltage to take over in a dead short condition is not easy. You have to match the chokes to the fuel cell, Then you have to match the frequency to that, Then depending on how many PPM is in your water you have to yet calculate for that, OH, and water volume, If you do all these calculations, "Or if you even know how to do them" Then i would say you could restrict amps in a dead short and allow voltage to perform its beloved work.
So if someone is saying they're going to make stans vic and demonstrait it,,, They had better know their stuff. Its one Tough cookie.
TheNOP
Quote from: Grumpy on February 02, 2009, 04:14:58 PM
yep
this can too, and can do more then just that too.
http://en.wikipedia.org/wiki/Magnetic_amplifier
and, no need of special steal alloys...
