HydroMeyers Vic
Started by Spewing, January 31, 2009, 03:02:14 AM
ramset
Gentlemen
Since he seems very pissed that I did not share this
This is a private PM to myself from user BUZZ
he VIC is the ground side of the circuit. The water mixed with ionized radicals is the positive side of the circuit. Da!
The highest voltage mosfet I own is around 900 volts. Without all that stainless RESISTIVE wire between the charged water and the mosfet you will smoke the mosfets.
The air/gas processor is in the back end of the injector in later model. Under the plastic cover by the spark plug wire is a filter and needle valve where the air goes in through an aspirator, gets radicalized by the gas gun (ozone), goes down through the center insulated tube / electrode, enters the tiny little resonant cavities and mixes with the water, hits the spray grills and "FRACTURES" hits gets further compressed in the taper resonant cavity where it hits the two ground electrodes and explodes.
The two electrodes are connected to the vic coil which is made of stainless so they don't donate electrons back to the water (LIMIT CURRENT FLOW) the SS coil does resonate and then gets switched to ground through the mosfets. The chokes limit current going to the mosfets.
The connector that controls the mosfets is on the side (Three contacts) The center contact is positive which drives the LED lasers in the gas gun and this process all happens in a fraction of a second.
Water going to the injector is at 120PSI.
That is how it fucking works. I built it a year ago with the plasma electrolysis which has been on my site ever since. Only one person to my knowledge ever had the fucking brains to put the plasma tube before the cell to produce those radical (O3 - O4) atoms  - me. It is called bond cleaving in general .
Oh yeah, if you want to draw energy from the circuit, connect it to that outer bifilar coil. I am pretty sure that connected to the resonant cavity boxes on the side which should contain a cap and a diode which is charged opposite the water so the water and gas exchange electrons. (bond cleaving)
END QUOTE
    Chet
Thanks Grandma
dankie
Seems far-fetched ...
Thats just sparks 2 day old half-baked idea , plz dont try to confuse the reader ramset ... Sparks is just an ordinary guy , even tho he has 2000 posts he is no Stanley Meyers , he probably read that off some other guy or from a site somewhere . When Sparks gets a bunch of international patents explaining his technique maybe I`ll start working on that ...
Evidence and common sense is always right
ramset
Dankie look up [before your last post]
Thanks Grandma
kinesisfilms
it can be done with copper....too a certain voltage level.....after that the amount of copper needed gets a bit ridiculous.....remember in stans patents of his earlier vic coil it was constructed with copper.
so to achieve the injector/ionization method voltages of 40kv must be obtained which can be done with wire consisting of a higher resistance but must still have an inductance factor.
Now lets look at his earlier achievements...splitting water with high voltage low amperage.
ELECTRICAL POLARIZATION PROCESS.
notice how the pulses are starting from a ground and building up to around 1kv (as stated in patent)
this means that the top pulse reaches let's say 1kv and each pulse leading up to that is a pulse of 200 volts, which all stack on top of each other hence step charging....COMMON KNOWLEDGE.
http://i2.photobucket.com/albums/y2/kinesisfilms/electricalpolarization.jpg
yes you can achieve voltages of 3,000 volts with copper wire on a small core easily.....this will separate the water.
but to ionize much higher voltages are needed upwards maxing around 40kv.
so let's look at his stainless steel wire coil.
FIRST OFF notice the very first pulse already achieves electrical polarization process woo that means we are now working with pulses of 1kv or higher.
http://i2.photobucket.com/albums/y2/kinesisfilms/HIGHPULSES.jpg
and as you can see the higher voltages are there to strip electrons and ignite unstable particles with "pressure."
NOW LETS SEE WHY HYDROCARZ VIDEO IS NOT GETTING THE CORRECT AMOUNT OF VOLTAGE WORK OUT OF HIS INPUT VOLTAGE.
he is simply applying it incorrectly.....yes he has high voltage (he might have low amperage BUT he is NOT showing us which is suspicious in content and his argument is that well no spark is just across the plates so therefore it must be low amperage BUT THERE ARE SO MANY suspicious things going on in that video that one has to always question)...so let's say he has high voltage and low amperage LETS JUST SAY THAT FOR TEACHING PURPOSES.
straight from a book:
he is applying it incorrectly anyways......let's look at electrical potential energy laws....when an electrostatic force acts between two or more charged particles within a system of particles, we can assign an electric potential energy U to the system.  If the system changes its configuration from an initial state i to a different final state f, the electrostatic force does work W on particles, we then know that the resulting change DELTA U = U final- U initial = -W........thus stan applied this from both sides of the water molecules via electrodes ALLOWING VOLTAGE TO PERFORM WORK IN A STEP CHARGING MANNER....INSTEAD OF A CONSTANT PRESSURE FIELD MANNER.
HONESLTY PICK UP A BOOK AN QUIT BICKERING
i feel like i am the only one who has read the ENTIRE tech brief MULTIPLE times....i always have to show pictures in order to stimulate interest.
Gobaga
This this thread is like a sado-masochistic free-for-all.
