DEK motor with U-coreless coil or Lenz boxing against Lentz
Started by woopy, February 02, 2009, 03:31:57 PM
woopy
@BEP
very interesting what you said about rotating a coper disk with a 8UCC  please go on searching for the photos   i made a
test today with a new 44 turns  ( i will try to make all the comparison with 44 turns of 0.5 mm copper wire       wound around a varta battery of 4.5 volt      and under the same battery power of 4.5 volts        its takes me about 5 minutes to make one UCC  so please replicate and retrofit your experience)    8UCC  and it could be interesting also for what i am looking for.
@all
see how i make very cheap rapid and accurate  test  to give the direction and power work      for the fine tuning i hope the Doctors will come in  ;)
and now let's go for the real things   i ordered  the magnets  this morning  and       let's go to the workshop
of course   and please  idea for the timing     power stage    and finally but atmost important the recovering of collapsing field
good night at all
et que la joie demeure! ;D
Laurent
Yucca
I've just built a pulse motor testbed with precision bearings. I will be experimenting with DEK UCC on it first.
I have not started the software yet, but initial specs are:
timing phase (10th degree resolution)
timing pulse width (10th degree resolution)
show RPM
show input power (true RMS)
I've ran the motor up using just the reed switch and it runs OK. The magnets are diametrically polarised, the poles appear on opposite sides of the circumference, the coil is 6cm diameter circle, 100 turns of 30AWG.
I am thinking of experimenting with shorting the coil during the exit phase by using a fast relay controlled by the micro, I'm hoping that maybe the perepetia effect can be made to appear and the BEMF can provide a physical kick out.
ramset
Woopy
looks like you hired a specialist [for your elec Doc]
Yucca that belongs in a museum [of tomorrows history]
Absolutely BEAUTIFUL build
  Chet
Thanks Grandma
woopy
@ yucca
almost      a swiss master piece :)
yes i am very happy that somebody takes the time to really experience the UCC  and how it  works     and not only how it works,  but you intend to do what i am not knowleged enough (yet)  to do    that is studying  the details of the  working principles
and  the output possibilities of the collapsing field
thank's a lot
@Ramset
This thread  is  the first  one where i go in       but i have in mind that we all have to do something to overcome a very mondial critical situation.   I can say to you that   3 years ago i  probably would have spent easily 10 000 euros to patent each of my ideas     and i  did  it   for the 3 previous decades      and i have really spent  around more than  100 000 euros  for that .    Furthermore  i was very  sceptical to open my brain to this forum    but it happens a very special history to a good inventor friend of mine       he patented one of his idea  (a very good one of  course)   the patent was world wide granted     and of course he spent   the mondial fees for that  and each years of course    and i can say to you that there is very    very expensive    and 9  (nine )  years    after   the worlwilde granting         a big company  got  interested to the idea   and as this company pay lawers at full job   they always come to results    and they found a failure in the patent     result patent     zero         think of it       !!!!!!!
@all
i am going on for the torquy DEK motor
the magnets are here  and now  lets go to the details   i will need probably 3 to 4 days to make the magnet holdings on the wheel + one or 2 days for the axle organisation
so the helpers  have  2 or 3 days from now to inform me   how about the coils  ;)        Gauge    turns   bifilar     i have  heard  of      Bob Teal       winding  (very interesting)  with strong  energy recovering  ?
input power      one  KOKAM lithium polymer  battery  40 AH ( 40 amps)  14  elements of 3.7 volt nominal  = 51.8 volts         4.2  volt maximal  at end of charge voltage =58.8 peak volts
input power  max 300 amps at  50 volts  = 15 000 watts (15 kw) max  for 1 minute
than about 6 to 8  kw for cruise flight
bravo a tous !
Laurent
Yes Ramset i have some knowledge   and very wide  but not so precise as you think    that's why i need you competence to go forward
woopy
and of course
i forgot the pictures of the project  :o
good night all
Laurent
