Thanks to ALL for your help!!
How to build a Rodin Coil
Started by magpie, February 02, 2009, 03:43:05 PM
nievesoliveras
@magpie
Here is the possible rodin coil joule thief configuration.
Jesus
Edit:
If the rodin coil has two coils, then the configuration is just exactly as the one used for the Joule thief toroid.
Yucca
Quote from: magpie on February 06, 2009, 09:39:31 PM
Aaah, thanks Yucca,
If you look at the first video I put up showing my first (the orange) coil, you can see there is a ten degree space between the first and second coil as per the diagram, should I be pushing the first and second coils together?
I should point out that my coils are also different in that they use insulated wire, I haven't gotten hold of uninsulated wire but do you know of a solvent for the shellac?
I wonder what happens if you make the first coils out of three winds and the second out of six, I might try fitting on a third coil of nine winds...
Hi Magpie,
If you can push the first and second coil together and end up with the gap being the same width as 1 coil band then that should give you the config as per Rodins spec. On a tightly packed coil then you could remove winds until you have one third gapspace and then push the coils together.
I think insulated wire is a requirement. Wire from TV degausing coil, like you´re using, tends to be good quality copper with good varnish, should be perfect.
I don´t know about winding one wrap with multiple of three and other with multiple of six. Rodin never mentions it, but it´s all worth experimenting with.
I can´t find much info about Rodin coils, so it looks like an exciting area of frontier research.
P.S.
If you´ve not watched them yet then do try and watch Rodins youtube vids, I watched them all over 3 nights a few months back, fairly easy and enjoyable watching. He handles a coil so you can have a good look at it.
nievesoliveras
@all
I did not want to say anything yet, but I am having a tremendous success!!!!!!
http://www.overunity.com/index.php?topic=6362.msg158838#msg158838
Jesus
jadaro2600
I expect that it would have to be a rodin-coil hybrid - where one solenoid was inside the rodin - and the two would interact accordingly; I suppose that this would have it's best effects if the inner coil were the lesser wound - for the voltage, and the inner were for the current - after all, that's what a rodin coil is for isn't it?
telemachus
I am trying to make an electronic circuit for my coil so that it can make a neodymium ball spin. I've tried out a few circuits including Jack Scholz's Rodin/starship coil circuits on youtube
but they don't work.
I'm actually using a Starship coil, which is similar to a Rodin coil, but easier to make.
Could someone post a simple Rodin coil circuit diagram/schematic that will make a metal ball spin? Thanks
