Real OU-Effect to Share with everyone!!!
Started by Magnethos, February 02, 2009, 08:37:03 PM
NRGFromTheVacuum
Quote from: scotty1 on February 28, 2009, 06:04:09 AM
Can someone just post the proper circuit that was used on the youtube clips.
Every drawing seems to be different all the time?
The guy shorts 3 wires together and uses only one cap that charges.
If somebody makes me a proper drawing that is unanimously agreed on, then i'll spend time on it and do whatever anyone wants...make video's ect....but PLEASE...let's have a drawing of the circuit that is agreed on first?
Some drawings say to use 2 caps...some show one cap, but only 2 wires shorted?
There needs to be one cap and 3 wires shorted!
Scotty.
Here Scotty.
lanenal
Interesting, different than I thought.  :o But thanks for sharing it! BTW, what is the inductance of the coil? By the proposed theory, the main purpose of the coil is to increase the relaxation time?
Quote from: NRGFromTheVacuum on February 28, 2009, 11:53:39 PM
Here Scotty.
hartiberlin
Here is the circuit diagram a bit better to see.
I deleted the part to discharge the right cap, cause it
confuses too much.
Regards, Stefan.
hartiberlin
Here is the other circuit from user STARK.
scotty1
Thanks Harti.....but too late for me... ;D
I sat down and worked it out myself.....
In the end I come up with the same circuit as your first diagram...later i'll test the other one.
Here is what I did.
I used my magnet motor to charge a 25V cap  ;D.....then I shorted the 2 wires to the metal plate.
My load cap charged to about 150v on average, with a 1V drop on the 25V supply cap.
Sometimes I got around 300V but not when I was filming...of course..(around 2 or 3 V drop of source)
I tried many coils and found that the low ohm coils worked best.
The 2 coils I used have 4 ohms each...1500 turns of 16g wire.
I made a video but it is still processing so here is the link to my you tube channel.
The clip should be available soon.
http://www.youtube.com/scotty7129
Something I noticed was that the test worked best when the timing of the short matched the rise time of the coil......because I've used these coils loads of times I know how long they take to reach their peak....that is how I got some 300V readings....but I lost about 2 or 3 volts on the source cap.
BTW..thanks to Magnethos for taking time to mail me.
Tomorrow i'll make some tests without the "split pos"  that i used this time.
Scotty.
